Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#11 | |
Any newer opamps to recommend? Perhaps OPA828 from TI? Less noise and bigger slew rate. Best regards, Domagoj
"When you steal from one author, it's plagiarism; if you steal from many, it's research." - Wilson Mizner |
#12 | |
![]() 1. So, Schottky diodes are OK (fast and soft) right? 2. Do I need a 100VA transformer (my maximum power consumption is 10W)? 3. If I can't find the 18VAC secondary, would 17VAC or 20VAC be better? Or does it have tobe 18? 4. The preamp has a common ground, do I still need separate secondaries? Thanks so much for your help! Alex |
#13 |
Two separate secondaries means that you can make two fully separate DC inputs for each reg (pos and neg) and only connect their grounds at the reg outputs. No common ground returns = cleaner outputs. You will have two rectifier bridges so two capacitors.
If you need only 10W you can do with a 30 or 50VA transformer, yes. If you can't find a an 18VAC xformer I would go for 20VAC, 17VAC is cutting it close especially with low mains voltages. Schottly diodes: not sure they are fast and soft recovery. They may be fast and they have low drop voltage, but look for soft recovery diodes. They switch off softly which lowers spikes. If you go to Mouser you can select diodes and progressively narrow it down to say 100V, 1A continuously. Probably https://www.mouser.be/ProductDetail/...%2FhqSiQ%3D%3D will do. Jan
Linear Audio - Articles - SilentSwitcher - Treg hi-voltage regulator - Hi-voltage delay unit - AutoRanger Last edited by jan.didden; 10th October 2020 at 09:14 PM. |
#14 |
Another option is to use the Omishra P/S from the A/K thread & the board (or completely populated) is available from Sachu888, the P/S was originally developed for the A/K AD797 MC phono amp & is very, very quiet.
Few more PCbs for AD797 HQMC phonostage for LOMc I also use the SilentSwitcher on my P/Amp at it's normal voltage, but the only way I can get it quiet enough for a Phono Stage is to feed it with a lithium 5v phone pack battery back up devise, Used like that it is quieter than the Omishra, but used in another 5V supply configuration it is louder. I have also used the Studer units & while they are very quiet, they are very unreliable. Had two fail within a year & neither Chinese vendor would replace the units or refund & E/bay also did not want to know!! Cheers |
#15 | |
here you have a collection of regulators used in some of the best phono gear ever made: FET vs BJT input phono preamp Are you really fine with IC voltage regulators ? FET vs BJT input phono preamp Are you really fine with IC voltage regulators ? Are you really fine with IC voltage regulators ? Are you really fine with IC voltage regulators ? Are you really fine with IC voltage regulators ? But if you really want something fast, this is fast and easy to build with readily available components around you: Are you really fine with IC voltage regulators ? you choose different zenner values so that you have a final +-18v if that's what you wish or simpler , use a 7808 /7908 as te original Technics denoiser and two 5v1 series zenners for the lowest tempco and best precision. although a 10v zenner can be used too. |
#16 |
Is sigma22 from amb.org not a candidate?
#17 |
May be, but a few good decades ago they started to manufacture op-amps for differential action...
This highendish trend for "fast transient power supply for class A phono circuits" needs to be put to rest as it's ridiculous. Even if we could claim that we need to supply fast phono preamps , which is a real nonsense as there's no fast phono preamp, its slew rate being determined by the cartridge itself which is an electromechanical transducer, thus slower than you might think, we never had in our history as good low esr , high ripple capacitors as we have today, and high value lower esr caps work best with slow regulators... The mere definition of "fast transients" put next to a amplifier for electromechanic transducers, tells you that these transients may be encountered from time to time and they can be easily supplied from a low esr cap accumulating the energy and releasing it fast just for those short fast transients. Simple truth is that we don't need that even with the fastest and highest energy eating phono preamps as they are class A. Last edited by dreamth; 10th October 2020 at 09:53 PM. |
#18 |
I power a buffer amp with lm49720 lme49600 with the sigma22 works perfect for me
#19 |
Hi safesphere,
Maybe I'm too late to recommend - but read this DIY Audio link first, I build it twice and it sounds more natural than any other PS for low power pre-amps... Another look at the LM317 and LM337 regulators Last edited by tubemax; 10th October 2020 at 09:58 PM. |
#20 | |
By the way...if a phono preamp really needs a fast regulator, that is a poor phono preamp right from the start. A good phono preamp won't allow for fast transients to be felt by the power supply. Last edited by dreamth; 10th October 2020 at 10:01 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
ultra low noise power supply and low noise amplifier | ambrosia168 | Power Supplies | 8 | 13th October 2017 03:43 PM |
Single supply vs. dual supply and noise, I can't find a proper solution | Plecto | Power Supplies | 16 | 2nd August 2013 06:14 PM |
Nice power supply with fast recovery diodes | peranders | Solid State | 3 | 24th August 2004 04:04 PM |
Super fast, low noise phono preamp | dioklecijan | Analogue Source | 30 | 19th July 2004 10:52 PM |
New To Site? | Need Help? |
