Help to understand and build regulated power supply
Old 1st October 2020, 08:40 PM   #1
Uylum is offline Uylum  Sweden
Default Help to understand and build regulated power supply
ive got some toroidal 24v 200va dual windings
ive got 20 of them could not throw them away..
i have some elektronic knowledge.
i want to build power suply for an amplifier.
ive been looking at
13.8V 20A linear power supply
i like the design but i vant higher voltage. up to 40v
can someone help me with this?
and can i put transformers in parallel and series for higher voltage and va?
Old 2nd October 2020, 02:13 AM   #2
PRR is offline PRR  United States
PRR's Avatar
24V AC to rectifier and capacitor will peak at about 35V DC. Two such schemes makes +/-35V DC. This is good for almost 70 Watts Sine in 8 Ohms. So one channel at 8 Ohms solid or 4 Ohms mildly saggy (maybe 110 Watts).
Old 2nd October 2020, 01:56 PM   #3
but if i put 4 transformers in parallel i get more��
Old 2nd October 2020, 07:24 PM   #4
Vovk Z is offline Vovk Z  Ukraine
It depends on a load impedance.
Old 2nd October 2020, 07:48 PM   #5
Galu is online now Galu  Scotland
I presume you are aware of the precautions to take when paralleling transformers?
Paralleling Transformers – An Electrician's Guide to Single Phase Transformers
Old 2nd October 2020, 08:15 PM   #6
yes i am
Old 3rd October 2020, 03:59 PM   #7
if i use this schematic as a start..
and use 35v DC that is too high voltage for lm741 can i use voltage devider or do i have to use another op-amp
Old 4th October 2020, 04:15 AM   #8
Rick PA Stadel is offline Rick PA Stadel  United States
Not sure what you mean by 'voltage divider', but a couple resistors, a zener, small electrolytic, and a pair of lowly 1N4148's (just to keep the inputs within the '741s power supply range) should be all you'd need to add. And a long list of op amps aren't that keen on supply voltages higher than 36V, including most of the popular ones.
The bigger issue (for me, at least) is 'are you planning to use this very tightly regulated, high-current supply for the main rails of an audio power amp?'
Because we usually don't regulate the high-current rails that supply the output stage -- just too much loss in efficiency.
Cheers
Old 5th October 2020, 03:42 PM   #9
i just want to tryout regulated powersuply and lern somthing at the same time
Old 7th October 2020, 11:48 PM   #10
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Dropping 35VDC to 13V is quite a drop and would need to lose some serious power as heat.
Unless you get a switch mode buck converter to drop it down.
2020 versions of PCBCAD51 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
Help to understand and build regulated power supplyHide this!Advertise here!
Trying To Understand This Power Supply Design colorcat Instruments and Amps 4 6th November 2016 10:50 PM
Regulated Vs Non-regulated linear Power Supply mbeards Tubes / Valves 2 30th January 2013 09:45 PM
Please help me understand power supply load deuce42 Tubes / Valves 6 6th January 2012 06:07 AM
CRC Power Supply design, help me understand it pjpoes Power Supplies 4 4th March 2007 04:46 PM
Trying to understand the Naim Armagedon power supply, please help pjpoes Analogue Source 2 14th January 2007 04:38 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
