Mean well vs generic power adapter vs  audio oriented smps
Thread Tools
Old 27th August 2020, 07:46 AM   #21
Sangram is offline Sangram  India
Sangram's Avatar
Yes, but those have quite a bit more noise and you have issues because there are now two noise sources in series. Depending on your DAC's current requirements, a simple TL431-based series regulator will be much better. Or an LM317, which is a much simpler circuit - at the expense of a bit of performance (almost negligible).
Old 27th August 2020, 08:08 AM   #22
auriga2001in is offline auriga2001in  India
Yes, LM317 for the DAC maks sense due to the low power requirements. But, can I still use the buck converter for other 5V applications like USB hub, chargers, etc? Basically, my question was regarding series connecting anything with input capacitors (like the buck converter) to the Meanwell smps.
Thanks.
Old 27th August 2020, 08:11 AM   #23
Sangram's Avatar
Yes, using a buck converter for non-audio applications is absolutely fine. Input caps aren't a problem as long as they're not diyAudio spec - which means below about 470uF. No buck converter I know has larger.
Old 30th August 2020, 11:01 AM   #24
profdc9 is offline profdc9
Default CMC power supply filter board
I am working on an audio amp and I designed a PCB for it because I originally planned on using two LRS-350-48 Meanwell supplies for it.
PowerAmpAudio/PowerCond at master * profdc9/PowerAmpAudio * GitHub
However, to use it, a metal chassis should be use so that the RF from the switching noise and other noise sources is separated from the supply rails.
Old 5th September 2020, 04:45 PM   #25
kasey197 is offline kasey197
The Dastardly Dad of Three
I did some measurements today for a Meanwell LRS350-48... loaded at 1A
- with L only - 8uH common mode inductor, and
- then L+C with 33kuF of capacitance (just to be absurd).
22hz-80khz bandwidth (and then in brackets Hi freq noise 20k-80k)
SMPS w/o filtering: 1.2mV (1.08mV)
L only filter : 457uV (62uV) ; wow that cm inductor really works !!
LC filter: 226 uV (11uV)
as above but with mains switch off: 184uV (4.5uV)
So not bad - adding some simple passive filtering makes these large & economical PSUs quite useful indeed.
ps the large cap triggers hiccup mode so beware ...
Old 5th September 2020, 05:30 PM   #26
Kyrk is offline Kyrk  Greece
At how much dbV does it get audible? Or thre isent a general rule? There is a large spike at 80khz how so? Do the transistors switch at such high speeds? You brought that curve down nicely, but should we even care about what happens after 20k? most speakers cant even reproduce those frequencies let alone the fact that class d output filters should turn them down, moreover who can hear after 20khz
Old 5th September 2020, 05:45 PM   #27
Sangram's Avatar
The switching frequency is 160kHz, looks like. The spike at 80 would be the half-cycle switching spike.
I'm concerned about the load being too low to properly test ripple. I could expect the ripple to hit about 30mV at 50-60% load, which while high would still be acceptable and that is when you see the greatest contribution of LC filtering post the supply.
While the 50Hz spike looks bad, even the worst designs will have about 40dB of ripple rejection at low frequencies and this is not a problem. Would be very happy to see some results at higher load, as Meanwell's own datasheets show much higher ripple measurements when fully loaded.
Old 6th September 2020, 09:47 AM   #28
Originally Posted by Kyrk View Post
At how much dbV does it get audible? Or thre isent a general rule? There is a large spike at 80khz how so? Do the transistors switch at such high speeds? You brought that curve down nicely, but should we even care about what happens after 20k? most speakers can't even reproduce those frequencies let alone the fact that class d output filters should turn them down, moreover who can hear after 20khz
True - nothing much beyond 20khz will eventually get amplified (or even reproduced !) Much of the ripple and noise is actually at lower frequencies tho so it makes the effort worthwhile...
Old 6th September 2020, 01:52 PM   #29
Here is the spectrum with a 4.5A load and as you pointed out - seeing more ripple. A second stage LC or a cap multiplier would clean this up nicely if required
Old 6th September 2020, 02:41 PM   #30
With no filter and 4.5A load ... and then with same filter as post#25 and 4.5A load
File Type: jpg lr350-48-unflitered-hirez-4.5Aload.jpg (331.9 KB, 91 views)
File Type: jpg lr350-48-LC-filtered-hirez-4.5Aload.jpg (331.7 KB, 81 views)
Mean well vs generic power adapter vs  audio oriented smpsHide this!Advertise here!
Thread Tools
Generic Power Entry PCB baseonmars Power Supplies 18 26th August 2020 08:46 PM
Google Chrome Audio power adapter is better than iFi Audio iPower? Solve Power Supplies 2 9th September 2019 12:57 PM
Generic Prototyping Board For Audio jkuetemann Parts 20 6th February 2015 06:44 AM
Power-oriented cap-meter Elvee Equipment & Tools 10 28th December 2014 08:39 PM
ORIENTED or Not ORIENTED cores for OPT ja2dhc Tubes / Valves 14 5th July 2008 01:31 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
