Which regulator for phono preamp?
Old 3rd July 2020, 06:46 PM   #21
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Originally Posted by billshurv View Post
what about the 7dB noise penalty that gives you? Or do you mean Cordell style 'damped' loading with an 8kHz roll off?
I was at the other location without my usual test setup. I ran this test several times with LME49710 and 47k and 11k load resistors and an Audio Technika VM540ML cartridge. I don't see the noise penalty. 7dB should be 2.2x noisier.
Old 3rd July 2020, 10:26 PM   #22
billshurv is offline billshurv  United Kingdom
billshurv's Avatar
11k seems a bit high for a cartridge in the 450mH area. I don't have numbers for the new stuff but my ATs are 360mH or less. I would expect you to need around 7K to get the 2122Hz pole. Hans simmed it with Marcel a couple of years back and here are is the quote from his post
I simulated 3 versions of a Riaa preamp, again with 500mH + 600 Ohm Cart and OPA1652.
The 3 versions differed in their Cart load resistances, resp 47K//200pF, 25K//200pF for a 8Khz pole and 6k//200pF for a 75usec pole.
All 3 versions were simulated with and without a "cooled" resistor, in this case by using a second OPA1652 with a gain of 10x.
This time I corrected the switched inputs of posting #152, giving slightly different results, but not much.
I won't display all images, that would a bit too much, but the final results are here with minus figures in red:
-------------Noise penalty-------"Cool" Gain---------Overall Gain/Loss
Version 47k ----- 0dBA ----------- 1.6dBA --------------- 1.6dBA
Version 25K --- 2.0dBA ----------- 3.1dBA --------------- 1.1dBA
Version 6K -----7.6dBA ----------- 7.3dBA --------------- 0.3dBA
Now this was pushing the limits of noise for MM stages mind.
Old 4th July 2020, 12:28 AM   #23
jackinnj's Avatar
I will be happy to repeat with Hans' values. I think, however, we are straying from the OP's purpose which is PS related.
Old 5th July 2020, 01:34 PM   #24
jackinnj's Avatar
Looking at the Measuring phono stage RIAA accuracy with a computer
I did not stimulate the cartridge -- a shortcoming in the measurements and looking at the thread a daunting task! (It took me a day to remember where I had seen the chart).
In any event, the LR Phono Pre seems worthy of a thread.
Old 5th July 2020, 10:04 PM   #25
billshurv's Avatar
We are, but I would be interested to explore this further if you ever find the time.
Old 5th July 2020, 11:03 PM   #26
itsikhefez is offline itsikhefez  United States
I ordered a SilentSwitcher, and I have the AMB sigma22 with transformer.
I'll try them both to see if there is an audible difference.
I would also be interested to measure for the learning experience, but I may not have the appropriate tools.
I have a Tektronix 2235A, a Fluke 87V DMM, and PC w/ ARTA and Pete's sound card interface (I also have Jan's autoranger on the way).
If possible, could someone recommend a useful test here?
Which regulator for phono preamp?Hide this!Advertise here!
Paradise phono preamp with pre regulator boards wirewiggler Swap Meet 0 7th May 2014 05:53 PM
Phono Preamp PCB wanted - Transcendental Sound Grounded Grid Phono Preamp nathanjh13 Analogue Source 0 14th June 2012 10:19 AM
18V phono preamp (super) regulator arlekin Power Supplies 3 30th January 2011 10:44 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
