Thread Tools
Old 6th July 2020, 06:49 PM   #21
DontHertzMe is offline DontHertzMe  South Africa
No Morse
DontHertzMe's Avatar
Boards for my layout are currently in production at JLCPCB. Once they're in hand I'll test them for stability etc. If all is well I'd be happy to post the gerbers here (with Mark's permission).
Mine are 2 layer instead of 4 layer (for cost reasons), size a bit bigger than Mark's at 10 x 13cm, and 2 fewer capacitors
Old 6th July 2020, 09:13 PM   #22
Mark Johnson is online now Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Hi, I prefer that you open a new thread with an informative title perhaps such as "VRDN Clone on 2 Layer PCB" or something like that, so members will know instantly that it's just a little different. By all means please post the Gerbers and I'm happy they will be freely available. Just not in this thread, lest confusion arise.
Thank you and congratulations!
Mark
Old 6th July 2020, 09:18 PM   #23
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Originally Posted by kasey197 View Post
Stuffed and tested....
RE...Posts 16& 17
Me Too:
Old 9th July 2020, 09:20 PM   #24
RickRay is offline RickRay  United States
Would a 100VA 18V Antek work well with this board?
Old 9th July 2020, 09:33 PM   #25
6L6 is online now 6L6  United States
6L6's Avatar
Yes.
It would be total overkill, but it would work nicely.
Old 9th July 2020, 09:40 PM   #26
I figured, I have one on hand and antek is out of stock on the 50VA. It will fit, i guess I'll use it, LOL.
Old 9th July 2020, 09:41 PM   #27
6L6's Avatar
Absolutely. It will be under low load and will likely run hum-free and happily cool.
Old 14th July 2020, 08:27 AM   #28
myleftear is offline myleftear  Switzerland
myleftear's Avatar
Default trying to get the gerber job done...
Hi Mark
hi everybody
Mark, thank you a lot for all those contributions you provide.
My line stage-kit will be arriving soon, so I'm getting nervous about the VRDN which I intend to use for it.
Since it got a bit quiet here, I couldn't resist and got myself a peek into the Gerber-files. Being on a mac, I had to find the appropriate tool for it and settled on "Cuprum", which opened / imported the zip-file without complaints. It looks cool and I don't know what to look at. So if I'd give it a shot, it would be with blind faith!
I don't yet know if all I'd had to do was send this to some PCB-maker...
I just tried it with the first I found: Eurocircuits, and they want some € 88.- /piece so that's a no-go.
Would somebody assist me, or has anyone some PCBs in the pipeline already?
thank you
david
dobedobedo...
Old 14th July 2020, 09:32 AM   #29
BrianGasberg is offline BrianGasberg  Denmark
BrianGasberg's Avatar
I got 10 made at jlcpcb.com for 30.4 EUR. They accept the zipfile provided by Mark Johnson directly.
I have attached an example of specs for ordering.
Builds: Aleph 5, B1 Korg, Whammy, F6, B1
Under construction: Waynes BA18 linestage, UGS Muse Preamp
Old 14th July 2020, 09:56 AM   #30
No Morse
+1 on JLCPCB. They're solid quality for little money. PCBWay is also a good choice.
Thread Tools
LTSPICE was wrong: MOSFET transconductance "gm" is NOT higher than bipolar gm Mark Johnson Solid State 33 13th January 2017 12:18 AM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 07:31 PM
Amazingly good "pop" recording... Nickel Creek "A Dotted Line" NewMountain Music 0 28th October 2014 04:54 AM
Line level SE to differential "fix-it" box Iain McNeill The Lounge 0 15th January 2010 06:09 AM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 7th September 2008 12:35 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
