Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#221 | |
I still need boards. Happy New Year. |
#222 |
PCBShopper – A Price Comparison Site for Printed Circuit Boards is a price comparator (for pcb-production), recommended by great Mark Johnson...
dobedobedo... |
#223 |
diyAudio Donor
Here's my invoice from May 2020. I bought 20 boards and paid USD 3.50 per board, including seven day express shipping to California USA. 1 ounce copper, no gold.
I found this PCB fab using the pcbshopper dot com comparison site. _ |
#224 |
The file I downloaded this:
Gerber File: TZPTR7_A_VRDN_regulator_rev_A.zip Not **** A _VRDN_regulator_rev_A_Y50 that you posted. Where do I get the correct Gerber file? Thank You. |
#225 |
dobedobedo... |
#226 |
Since there is very little noise on the output of the VRDN, would it make sense to add a 5volt regulator off the output to provide for a digital power line? Would this mess up the output impedance of the VRDN, does it make sense?
I'm currently using a low noise DC2DC converter to get my +-5Volts I need. |
#227 |
This is possible of course, but would you really want to mix the analog and digital grounds via a (common) power supply returns? If it's a DAC you are talking about and its USB stage has an isolated input/ground, then this approach will simply not work because the grounds, once isolated, will be commoned together at the power supply.
However, if you use a SECOND VRDN as pre-regs, purely for a dedicated LT3045 / LT3094 voltage regs (for example), positioned very close to where they are needed... |
#228 |
Has anyone measured what the noise floor is with the VRDN board. I'm not concerned about the board, I'm using it and it is AWESOME. I'm trying to sort out a measuring set-up including an LNA to measure low level noise. I'd like to verify my test set-up.
#229 |
diyAudio Donor
I haven't calibrated an LNA myself but I have read a few posts on diyAudio over the past few years, written by people who were doing that very thing. They seem to prefer using the Johnson-Nyquist "thermal noise" of a 1% metal film resistor, since this noise is (a) determined by basic physics and not by good/bad circuit design; and also (b) accurately known in advance.
Most of them choose a 1K resistor to do their calibration, which gives a noise voltage density of 4.07 nanovolts per root Hertz, as shown in the Wikipedia article excerpted below. _ |
#230 | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
LTSPICE was wrong: MOSFET transconductance "gm" is NOT higher than bipolar gm | Mark Johnson | Solid State | 33 | 13th January 2017 12:18 AM |
"Digital Line Level" and "Dital Source" forums.. | terranigma | Forum Problems | 7 | 13th December 2016 07:31 PM |
Amazingly good "pop" recording... Nickel Creek "A Dotted Line" | NewMountain | Music | 0 | 28th October 2014 04:54 AM |
Line level SE to differential "fix-it" box | Iain McNeill | The Lounge | 0 | 15th January 2010 06:09 AM |
Linear voltage regulator: how to make good use of "sense" and "ground sense"? | NeoY2k | Analog Line Level | 7 | 7th September 2008 12:35 AM |
New To Site? | Need Help? |
