Old 9th September 2020, 10:52 AM   #131
booja30 is offline booja30  Spain
@myleftear
I think it's pretty common to offer additional ground connections for convenience, but I don't think it's necessarily a hint that you need to find uses for them.
My plan is to have each VRDN assigned to strictly one half of the BA2018 board. So the input side of the VRDN would have transformer secondaries connected. The output side would have OUT+, GND, and OUT- connected to the 3 corresponding inputs on the preamp board. In addition, one of the spare GND terminals would connect to a CL60 (or similar) NTC to provide a 'floating' ground to the chassis in case of a fault.
I don't think there is any need to connect each VRDN's GND to both channels of the preamp. If you wind up with hum it might be something to experiment with, but otherwise I think it is ok to treat them as fully independent. In other words, aside from the selector and volume pot, everything else could theoretically be installed in separate chassis.
Apologies if I misunderstood the question. And you know I'm not an expert , so I would appreciate feedback from others on what I've written.
  Reply to this post
LTSPICE was wrong: MOSFET transconductance "gm" is NOT higher than bipolar gm Mark Johnson Solid State 33 12th January 2017 11:18 PM
"Digital Line Level" and "Dital Source" forums.. terranigma Forum Problems 7 13th December 2016 06:31 PM
Amazingly good "pop" recording... Nickel Creek "A Dotted Line" NewMountain Music 0 28th October 2014 03:54 AM
Line level SE to differential "fix-it" box Iain McNeill The Lounge 0 15th January 2010 05:09 AM
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 6th September 2008 11:35 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
