PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXG
Old 26th May 2020, 02:53 PM   #11
BrianGasberg is online now BrianGasberg  Denmark
BrianGasberg's Avatar
Thanks for sharing this design Mark - it will fit very nicely in the F6 i am currently building
A suggesting for future revisions, if i may, could be an external trigger input
Old 26th May 2020, 06:55 PM   #12
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
Hi Brian, thanks for your input! I haven't met very many people who are enthusiastic proponents of external triggered on/off control. Would you mind saying whether you're actually using it today, in your everyday setup? Or are you thinking about PCB features that might be useful to others? Or useful to yourself, one day in the possible future?
Old 27th May 2020, 07:09 AM   #13
Hi Mark, i am not using it now - but i want to
I am listening to Roon via an always on raspberry pi. What i am working towards, is using a GPIO from the rPi to trigger the DAC, and then the rest of the chain. A while back i started designing a PCB which, apart from the functionality on your PCB, has trigger in/out (with apropriate trigger out delay) and loss of AC detection (for speaker relays). However i have way to many projects, and with your well engineered PCBs, i am one step closer to finishing my F6
I will propably have three extra PCBs in Denmark, if anyone is interested.
Builds: Aleph 5, B1 Korg, Whammy
Under construction: F6, B1, Waynes BA18 linestage
Old 27th May 2020, 12:09 PM   #14
kodabmx is offline kodabmx  Canada
Spreading triode love.
kodabmx's Avatar
I use this for low voltage on off...
What does yours do that this doesn't since I assume it will cost more than 3$ to build it...
12V Bond Bistable Relay Module Car Modification Switch Start Stop Self-Locking | eBay
EDIT: Yours does soft start, this one doesn't. Not sure how I missed that, but since I was using a 120V switch with no soft start before it made no difference. When I need soft start, it's accomplished with a time delay relay that shorts a 500R 20W resistor.
If you can't learn to do something well, learn how to enjoy doing it poorly.
Old 28th May 2020, 06:55 PM   #15
diyAudio Donor
By the way, if anyone wants to make before-and-after photos of inrush current, with and without countermeasures (this board, a different board, etc.), maybe the little homebrew test fixture I built a couple years ago might be a useful starting point. A circuit schematic and photo of working fixture are in post #41 here. If that link isn't working the post date was 16th Dec 2018.
I used the MOC3063M optocoupler and the BT139 triac back then; they worked well for me and the cost was low. So I used the same parts again, in this AC power relay board; they're known good.
Notice the double dose of conservatism in post #41: galvanically isolated, battery powered switch, AND gloves. With good result: many tests but zero electric shocks to the operator (me).
Old 30th May 2020, 12:11 PM   #16
diyAudio Donor
Here is an example of the AC power relay board, mounted on the 10 x 10mm grid of a Modushop chassis baseplate. This PCB is the one indicated by a yellow arrow on the photograph.
For the front panel switch, I used a 19mm diameter, illuminated pushbutton that I bought from Newark (link)
_
Old 3rd June 2020, 02:12 PM   #17
iamwhoiam is offline iamwhoiam  United Kingdom
Bravo Mark, really helpful design, thanks!
Old 3rd June 2020, 02:50 PM   #18
diyAudio Donor
Thank you very much!
If you're thinking of doing your own board, please also have a look at the design by member Bensen (links in post #8) for additional ideas. Plus of course, the original sources linked in post #1: Pass, Elliott, Cordell, Self, jhofland, T.I., Bryston, Ganssle et. al. Between all of them you'll get a bunch of ideas and a bunch of already-proven subcircuit blocks, which you can mix and match and tweak and fiddle, however you please.
Old 3rd June 2020, 08:08 PM   #19
pfarrell is offline pfarrell  United States
pfarrell's Avatar
I just made up a couple of these boards.. Thanks Mark!!
Found an error in my cart!!—fixed here:
Mouser Electronics
I'll post some pics of the built boards later...
Suffice it to say I learned a lot about soldering—and I wouldn't say I'm a novice there—but I had to go up 100 degrees F to get some areas to flow... Assuming that's due to the fact that more than half the board is copper...? The experience was the same for both boards... Kinda interesting...
Old 4th June 2020, 12:11 AM   #20
pfarrell's Avatar
And a pic...
I made two since I'm putting them into M2X mono blocks...
Sweet!!!
I vote for this getting the blue mask treatment and being added to the DIY store. I woulda opted for black mask personally... but it was a hefty upcharge.
PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXG-acpr_0012-jpg
PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXGHide this!Advertise here!
soft start question ... no relay ... emilvv Power Supplies 15 15th August 2018 05:00 PM
where is soft start relay inserted in PSU circuit necplusultra Power Supplies 34 27th January 2013 12:09 AM
PCB Relay for ESP soft start board wytco0 Parts 6 8th August 2009 08:23 AM
Relay for soft start robomatique Class D 3 6th December 2007 06:38 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
