PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXG
Old 27th September 2020, 09:12 PM   #171
amandarae is offline amandarae  Philippines
amandarae's Avatar
Additional Pics.
First Pic- power connected to L,N, and Chassis, switch open, LED Off is illuminated, lamp (RadioShack) connected to P1D and P1N illuminated (85 Vac Measured across P1D and P1N, P2D and P2N).
Second Pic - switch close, LED On illuminated, lamp still lit but brighter (120Vac measured across P1D and P1N)
I saw Marks post (#126) and says
"Another experiment you can try, is to connect a very low wattage, mains-powered incandescent light bulb where the transformer primary would go. A bathroom night-light (3W in USA) would be perfect. Presto, the bulb does not light".
In my case, the lamp is always ON but just varies in intensity.
The power supply of my power supply is my FRIEND!
Old 27th September 2020, 10:29 PM   #172
amandarae's Avatar
Hah! I finally figured it out!
When configured for 115Vac double primary, if you leave one set (say P2D and P2N) open, it acts what I had experienced. Need both sets, I use 100K resistor, with a load. After that, works fine.
Mark I believe already mentioned similar this but took me a while to find the documentation on the thread.
Abe
Old 28th September 2020, 08:46 AM   #173
diplomata is online now diplomata  Portugal
Hello everyone
And finally my H9KPXG works excellently, just connect the transformer to P1D and P2N, this for the 230V configuration and the strange readings are over.
In the pictures you can see H9KPXG already installed on the BA-3 chassis. If you are intrigued by the appearance of that same chassis, let's say I learned that you never buy the chassis first, or you end up with components that do not allow you to close the lid ...
A help for those who are in Europe and want to use Mouser to order components for H9KPXG, in Europe, Meanwell AC to DC module is not sold to private customers (only to OEM customers), you can replace it with one from Recom, Mouser part N: 919-RAC02-05SGA, the only difference between them is the price, the Recom being slightly more expensive.
And now I saw that Ripster had already indicated an alternative for the AC / DC module as well.
My thanks again to Mark Johnson for his generosity in sharing this project with us.
Best regards
Carlos
Old 4th October 2020, 09:25 PM   #174
A321Drvr is offline A321Drvr
Default H9KPXG Availability
Any one have any H9KPXG boards for sale in the USA?
Old 4th October 2020, 09:52 PM   #175
6L6 is offline 6L6  United States
6L6's Avatar
Might be a great opportunity to get a batch and sell the rest to other interested people!
Old 4th October 2020, 11:49 PM   #176
Audiobear is offline Audiobear  United States
Audiobear's Avatar
PM me. I might be able to spare one for you.
WHAMMY, SSII, Noir, ACA, M2X (with H9KPxG)
Old 4th October 2020, 11:50 PM   #177
Audiobear's Avatar
And @6L6 is right. Ordering these boards was the first time I had ordered PCB by submitting the Gerbers. It's a good learning experience.
Old 6th October 2020, 04:40 PM   #178
mvaldes is offline mvaldes  Italy
Is there any one that have a couple of boards to sell in EU?
Michele
Old 7th October 2020, 10:13 PM   #179
elwood625 is offline elwood625  United States
elwood625's Avatar
My PCB's arrived from China, and I found the Meanwell relay's,only took a week to get them. The first one is for the Singing Bush SIT amp which I have a 48v 1000va torroid. The soft start has the 250 Joules thermistor for the mongo transformer.
ACA v1.6 monoblocks, Balanced Zen Line Stage, M2x, Aleph J, H2, B1 Korg triode, 12AX7a Phono amplifier, Balanced B1 Korg triode, 6FG6 "Magic Eye" tube VU meter, FS NJFET RIAA
Old 7th October 2020, 11:54 PM   #180
Mark Johnson is offline Mark Johnson  United States
diyAudio Donor
Mark Johnson's Avatar
WHOA! That's spectacular, elwood625! Congratulations. I think you might be the first builder to drop in one of the 250 Joule ICL discs and show a photo -- it's extremely cool.
Very nice looking assembly with neat soldering and beautiful flux clean-off.
Now there's another 250 Joule Sumo Wrestler in town. Wimps had better get out the way.
PCB: low voltage On-Off switch drives AC mains relay \ includes soft start .. H9KPXGHide this!Advertise here!
soft start question ... no relay ... emilvv Power Supplies 15 15th August 2018 05:00 PM
where is soft start relay inserted in PSU circuit necplusultra Power Supplies 34 27th January 2013 12:09 AM
PCB Relay for ESP soft start board wytco0 Parts 6 8th August 2009 08:23 AM
Relay for soft start robomatique Class D 3 6th December 2007 06:38 PM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
