About these transformers
Old 29th March 2020, 01:49 PM   #1
ToFa is offline ToFa  Bangladesh
Default About these transformers
Hi there,
I was just testing these transformers I've got from wasted electronics. The big one is giving 11.xx Volts AC and the small one is 9.xx Volts AC but when I'm using a full bridge rectifier made out of 1N4007s and a 1000uF 35V capacitor I'm getting 22.xx Volts DC from the big one and 14.xx Volts DC from the small one.
Small one's DC voltage looks alright but I don't understand why the big one's DC voltage is multiplied this much. Why is it giving higher DC voltage? Is it because the current is higher and the diodes couldn't pass that much current. So in order to balance the power the voltage has raised!!!
Old 29th March 2020, 02:06 PM   #2
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Probably because there is no load.
2020 versions of PCBCAD51, PCBCAD360 and PCBCAD720 out now >>> https://www.murtonpikesystems.co.uk
Old 29th March 2020, 02:25 PM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
As Nigel said, provide each with a moderate 100mA load and then take your measurements again.
Old 1st April 2020, 11:07 AM   #4
Thanks both of you sir. I understand it now.
  Reply to this post
About these transformersHide this!Advertise here!
Onetics level 1 5k SE transformers , PP interstage transformers limono Swap Meet 8 18th April 2020 10:42 AM
The ISO-Tango transformers reborn in ISO Transformers Duebass77 Tubes / Valves 47 10th October 2019 06:07 PM
Altronics M1115 Line Transformers and two 24/25 vac transformers tomlang Swap Meet 0 15th August 2019 03:42 PM
Making CT transformers from two transformers infernal Parts 1 14th July 2011 08:42 AM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
