Battery P/S
Battery P/S
Old 26th March 2020, 04:55 AM   #1
gigigirl is offline gigigirl
Default Battery P/S
Hi Guy's, Well today is the 1st day of our lock down, so I decided to have a clear out (long overdue). In doing that I found this that I made up a few years ago. Battery supply from a cordless drill battery. It is set to output 12 VDC from a higher voltage battery, I tried it with a 18 VDC & yes it still works.
Very simple circuit that a friend of mine put together (I am not good at such things, but at least now I understand it) using the venerable LM317, 2 resistors & 2 small caps.
I have a redundant phono amp that it will be ideal for.
However beware, when I made it up I had a switch To allow me to charge the battery in-situ, (BAD IDEA) as I left it charging to long & it fried my ISO phono amp & 304 cart. So don't put the option it in yours if you decide to make one.
Old 26th March 2020, 03:09 PM   #2
sgrossklass is offline sgrossklass  Germany
I don't get that part. Why would this fry your load? I mean, the LM317 is rated for up to 37 V input, and it's a regulator after all. Given a decent enough minimum load, I wouldn't expect it to have much of an issue keeping the preset voltage even if input voltage were to increase, assuming heatsinking is adequate.
Other than that, the circuit is obviously more than minimal and nothing resembling "low-noise" with no ADJ pin capacitor in sight.
Old 27th March 2020, 05:34 AM   #3
Default No idea, All I know it did.
Old 27th March 2020, 08:49 AM   #4
AllenB is offline AllenB  Australia
AllenB's Avatar
Battery P/S
What turntable do you have in mind?
Old 28th March 2020, 05:25 AM   #5
Not sure I understand this question. This is a simple battery P/S for a simple MM or MC phono amp.
Voltage range from 12 to 24 VDC.
Cheers
  Reply to this post
Battery P/SHide this!Advertise here!
Voltage divider noise into a battery powered dac - battery voltage a bit high bigino Digital Line Level 12 9th October 2017 02:06 PM
Battery powered phono stage battery type advice Hikari1 Analogue Source 5 10th September 2013 09:00 PM
+/-18V & +48V from a battery jeppix Power Supplies 24 27th November 2012 02:53 PM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 02:18 PM
Battery VoLCoM Parts 1 17th August 2003 08:45 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
