HELP -  LM337 supply problem
Old 21st February 2020, 08:47 PM   #1
poynton is offline poynton  United Kingdom
poynton's Avatar
Default HELP - LM337 supply problem
Hi All,
I am having a problem fault-finding on the PSU in my Arcam Alpha CD 6.
The section is in the picture below.
The input to the LM337 is correct at 27v.
However, the output is only 1.5v.
I have changed the regulator but it is still the same.
The supply goes to the muting relay circuit and to the -ve supply for the opamps.
Any help fault-finding gratefully received.
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 21st February 2020, 08:58 PM   #2
rayma is offline rayma  United States
A bad part may be drawing too much current. Check D4, D7, C41, C42, and the opamps and their -15V bypass caps.
Did this unit work properly earlier, or did you get it this way?
Old 21st February 2020, 09:02 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
With an output at 1.5V (very close to 1.25V), C41 would be the prime culprit: try lifting one pin (assuming everything dowstream has been disconnected)
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 21st February 2020, 09:10 PM   #4
MarcelvdG is offline MarcelvdG  Netherlands
C41 shorted, R57 shorted or R54 open-circuited?
Old 22nd February 2020, 01:06 AM   #5
PRR is offline PRR  United States
PRR's Avatar
You do know that the 337 pin-out is different from 317 pin-out?
(How did I discover that?)
Old 22nd February 2020, 06:50 PM   #6
poynton's Avatar
Thanks for the input, guys.
It will have to wait 'til after the weekend -- rugby!!
and .. yes, I did know about the pin differences.
Andy
Old 22nd February 2020, 08:41 PM   #7
PRR's Avatar
I'm glad you knew; but I'm sure someone will come along not-knowing and become enlightened.
I know the physical reason the pinouts differ (most negative major circuit is die-bottom and is soldered to the heat tab). But it baffles almost everybody first-time.
HELP -  LM337 supply problemHide this!Advertise here!
My take on LM317 / LM337 power supply PCB BamboszeK Power Supplies 16 19th March 2020 06:41 AM
LM317 / LM337 power supply gerrittube Power Supplies 13 20th January 2020 05:20 PM
lm337 negative bias supply. Minimum load? bullpeters Power Supplies 1 12th September 2012 03:53 AM
Using LM338 and LM337 for 250VA supply camus Power Supplies 2 10th February 2012 04:26 PM
Not polarized electrolytic capacitor in power supply (LM317 LM337) ygg-it Power Supplies 5 19th October 2008 07:25 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
