Need help with power supply: Diatone DP-EC! turntable.
Need help with power supply: Diatone DP-EC! turntable. Please consider donating to help us continue to serve you.
Old 25th January 2020, 12:14 AM   #11
sgrossklass is offline sgrossklass  Germany
Do you get any DC voltage on C313/R305?
I suspect you might have a short on the +12V somewhere that's pulling everything down.
If it's not too much hassle, try disconnecting the RED wire at #23 and measuring again. You can also try measuring resistance to ground at this spot before/after (with power off).
BTW, the solder joints on the transformer primary look a bit crusty to me, the 0 V in particular. That clearly wouldn't be helping matters. Any change of output voltage if you wiggle the cable? A bit of flux and fresh solder may be appreciated.
Is the power switch delivering a decent enough contact resistance?
A flaky primary connection or power switch are about the only reasons I can think of for why unloaded voltages were higher than loaded. Well, either those or a flaky thermal fuse... At times these have been known to go bad all by themselves, but here the potential short on +12V might just have sort of degraded it. Maybe try getting a resistance reading on the primary and observing whether tapping the xfmr changes anything.
Worst case would be some shorted turns. That would make the transformer get quite warm though.
Old 25th January 2020, 12:27 AM   #12
cal16v is offline cal16v  Australia
Originally Posted by PBR
All three places the schematic says "120V" have a halo like someone pasted-in a change. Like 240V is the base design, a 120V model was sold in the US, and the scan was taken from a US manual.
Your transformer shows a "240V" winding so you are probably OK.
Yesterday 08:32 PM
Thank you. Nice to know the unit is unmolested.
Old 25th January 2020, 12:29 AM   #13
Originally Posted by rayma View Post
Seems to be a problem there. What's the DCV at #14, #20, and #24 wrt #18 ground?
Here we go!
#14 - 25.7VDC
#20 - -21.6mVDC
#24 - 5.82VDC
cheers
Old 25th January 2020, 12:36 AM   #14
Ok just following the path from #14, 20 & 24 and they lead to this!
Old 25th January 2020, 12:57 AM   #15
rayma is offline rayma  United States
Are you kidding me? Those tabs can't touch anything, they're all at different potentials.
Old 25th January 2020, 01:05 AM   #16
No joke rayma. I just followed the power to these 3 transistores and found what I found.
if it's any consolation they were sheathed in old plastic tubing.
Old 25th January 2020, 01:06 AM   #17
Can I still buy these or is there any replacements?
Old 25th January 2020, 01:09 AM   #18
Does that look original, or did someone do that after the fact? Terribly shoddy practice.
Check them unpowered with a dvm on the diode function. At least one is good.
Old 25th January 2020, 01:11 AM   #19
https://datasheet.octopart.com/2SD33...t-15979812.pdf
Bipolar Transistor Cross-reference Search | Equivalent Transistors
Old 25th January 2020, 01:17 AM   #20
DIATONE DP-EC1
The pi8c there shows a mounting panel for these in the bottom right corner. I suppose I could fashion something to secure them.
Generally, I get the impression someone else has been in and around the power side of things.
Need help with power supply: Diatone DP-EC! turntable.Hide this!Advertise here!
DIY Turntable Power Supply pelosi Analogue Source 64 16th October 2015 06:29 AM
Turntable power supply branet Analogue Source 5 17th July 2015 11:11 PM
Turntable Power Supply DIY needed promitheus Analogue Source 14 21st August 2006 01:02 PM
Turntable Power Supply passing thru Analogue Source 3 23rd December 2003 10:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
