LD1084 vs LM317 @ 24v
LD1084 vs LM317 @ 24v Please consider donating to help us continue to serve you.
Old 10th January 2020, 01:52 AM   #11
dotneck335 is online now dotneck335  United States
The LM317 is rated for a maximum of 40 volts of input-output differential---ONLY. There is no 30 volt maximum input as has been suggested. An allowance for a 3 volt dropout is indeed desirable. The LD1084, however, DOES have a 30 volt max input, but offers a 1.3 volt dropout----which could be a critical requirement in some applications.
Old 10th January 2020, 11:46 AM   #12
MorbidFractal is offline MorbidFractal
Use the 317 and check the resulting voltages in circuit when actually used in the target application. If the measurements say the 1084 can hack it replace the 317 with the 1084.
Old 10th January 2020, 03:13 PM   #13
soundwavesteve is offline soundwavesteve  United States
Thanks for the additional info - I will probably have it powered up this weekend
Old 10th January 2020, 04:34 PM   #14
keilau is offline keilau  United States
Originally Posted by soundwavesteve View Post
Hello,
I am building the Dual/Biploar LV-Reg power supply from glassware/Tubecad and have two questions. I did email John@glassware a few days ago but I understand of course he might be really busy and hasn't had a chance to reply...I am itching to continue my build
I am confused which regulator to use. The bag the LM317 comes in says use if Raw V is >30. As I am building this supply for 24Vdc, raw input is about 22Vdc. In several places online and in the instructions, he states "If the output voltage is greater than 20Vdc, then the LM317-HV will have to be used as the LDO three-pin regulators present a 30V maximum input voltage". Since this kit is rated for 24V maximum output, input voltage will always be lower than 30V....so why use the LM317? I looked at the spec sheet for the LD1084 and it seems capable of 24Vdc output...the input voltage and output differential are within spec.
I would just use the LM317 and keep building, but he states the LD1084 is a great positive regulator and I am curious why it cannot be used in this application.
I am running the FirstWatt BA-3 as a preamp and I don't know what load it presents, but the article talks only about mA's....
Second question, which you may not be able to answer without seeing the schematic, but R3 is part of a CRC filter but also reveals the current flowing into the load via measuring voltage drop. R3 can be .33, 1, 3.3 or 10 via the provided parts. The instructions state I could use 10ohms if the load is light. What is 'light' exactly? How do I pick which resister to use?
Check out the The LTŪ1083 series from Analogue Device. 30 volts rating up to 7.5 amperes.
https://www.analog.com/media/en/tech...s/108345fh.pdf
LD1084 vs LM317 @ 24vHide this!Advertise here!
How HOT should a LM317 get? brucetassin Tubes / Valves 17 24th December 2013 06:25 PM
LM317 happy hippy Power Supplies 63 20th January 2012 06:31 PM
the 1.25v of lm317 Albrerta Power Supplies 11 19th May 2010 12:02 AM
Lm317 Reg geowhitt Parts 2 30th August 2008 09:39 AM
LM317 getting hot! DieterD Everything Else 23 9th April 2002 10:57 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
