E-bay power supply running hot.
Old 10th January 2020, 06:40 AM   #11
ColinA123 is offline ColinA123  United Kingdom
The intention was to use this as a low noise supply for a BA3 pre-amp.
Old 10th January 2020, 07:07 AM   #12
FauxFrench is online now FauxFrench  France
Originally Posted by avtech23 View Post
Out of interest, what would be a typical use for a shunt regulator?
As "Katie" (or her dad) writes, shunt regulators can be designed for very good noise performance and very fast load step response. I guess most are used in delicate measuring designs.
The design procedure (in short) is to determine the load voltage and in particular the absolute maximum and absolute minimum load current. Design a current source (eventually just a simple power resistor) that always delivers a little more current than the absolute maximum load current, Finding a power source that ensures the current source will function well (also worst-case) but with a moderate power loss (no excessive voltage). Design a shunt-regulator with good dynamic performance that power-wise can handle the current source current minus the absolute minimum load current. In principle a straight forward design method but with a load having importantly varying consumption, you soon understand the power loss that is inherent with that type of design.
Hence, for that type of voltage regulators you design around the load characteristics. You do generally not just do as with series regulators, make a general voltage regulator and let the user find an application.
Old 10th January 2020, 07:23 AM   #13
If you can tell me the operational voltage, the absolute maximum current consumption and the absolute minimum current consumption of a BA3 pre-amp, we can adapt the regulator design.
E-bay power supply running hot.Hide this!Advertise here!
TPA3116D2 in PBTL Mode, running 4 Mono Boards on one Power Supply Turbowatch2 Class D 34 10th April 2018 11:24 AM
Half bridge power supply, running on single rail DC? Djmagnum Power Supplies 9 12th November 2017 12:15 PM
power supply? running off a generator ArcticBreaze Instruments and Amps 8 13th March 2012 07:56 PM
ESL Bias Power Supply running 2 seperate panels? dochungwell Planars & Exotics 5 12th July 2011 11:45 PM
World copper supply running out!!! Nixie Everything Else 66 4th March 2007 03:36 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
