Regulated Split Rail Supply Sagging
Old 8th January 2020, 07:55 PM   #11
Puffin is offline Puffin  United Kingdom
Originally Posted by Osvaldo de Banfield View Post
I didn't doubt in your skills nor that the circuit will not work, I only say that simple things usually do its job better than complex solutions.
No, I didn't read it that way. I should not look at the parts count on the stuff on ebay and think it is good value for what the parts would cost me to make it myself.
Old 8th January 2020, 08:06 PM   #12
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Well, the transformer looks decent sized, so the most likely reason is the preamp draws more than the 125 mA the current limiter is set to. As Jan says, measure at different points in the circuit.
No one wants advice - only corroboration.
John Steinbeck
Old 9th January 2020, 11:38 AM   #13
I am thinking of ditching the current limiting and modifying the board. In the past I have had success with adding a power transistor to the circuit to boost the current as in the link below.
https://www.eeweb.com/extreme-circui...ooster-circuit
Old 9th January 2020, 05:49 PM   #14
UPDATE: Whilst checking the current draw at different points on the board I seem to have killed something! Oh well, I should have made it myself anyway.....which is what I will do now
Old 9th January 2020, 05:55 PM   #15
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
It happens frequently. When searching with the DMM test leads in an IC, for example, and move the vision to DMM's display, the points move itself or by an error in hand movements, and pufff: the thing makes smoke by it 4 sides.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Regulated Split Rail Supply SaggingHide this!Advertise here!
Sagging Positive Rail Help. ammel68 Power Supplies 17 14th May 2017 09:19 AM
Adding single rail amp to split rail amp power supply jdelange Power Supplies 2 1st August 2016 09:46 AM
Split-rail DC from DC laptop power supply? hvergelmir Power Supplies 31 4th October 2015 02:15 AM
GC Split Rail Supply Puffin Power Supplies 24 8th February 2012 05:32 PM
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 06:18 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
