SMPS transformer varnish
SMPS transformer varnish Please consider donating to help us continue to serve you.
Old 8th January 2020, 07:31 PM   #11
Osvaldo de Banfield is online now Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
I do it outside my house, outdoor as it is said.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 8th January 2020, 07:37 PM   #12
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Of course. I hope you're wearing gloves, 'cause chloroform easily penetrates the skin?
Best regards!
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." (George Best)
Old 8th January 2020, 08:04 PM   #13
SemperFi is offline SemperFi  Wake Island
I would use a marine lacquer or varnish which remains a little elastic.
Dont use epoxy on ferrite core traffos since it becomes too hard and the core can break during use.
Air has dialectric constant of about one, lacquer and paints have at least 2, probably 3-4. So after lacquer the capacitance will increase by the same factor. That probably does not matter but must be concidered.
You should not get a more quiet SMPS b/c the frequencies are too high to hear anyways. But there are good reasons to impregnate a traffo. Google.
I canabalized a vacuum pump from an old refrigderator. A small bucket just big enough for the traffo. Fill up varnish. Have a lid with a tube to the vacuum pump. Vacuum. The air bubbles out of all crevises and varnish is sucked into all gaps. Done.
Old 8th January 2020, 08:08 PM   #14
Do you mean the fridge's compressor?
Best regards!
Old 8th January 2020, 08:22 PM   #15
wrenchone is offline wrenchone  United States
wrenchone's Avatar
Varnish impregnation certainly does affect the intra and interwinding capacitance of a transformer. It has been documented at my workplace countless times by measuring the transformer primary resonant frequency before and after varnishing. The resonant frequency always shifts substantially down after varnishing, indicating an increase in winding capacitance.
If I were going to varnish a transformer using stuff just available from the local hardware store, I would just use a good polyurethane varnish with no stain.. For a "poor man's vacuum impregnation" method, heat the finished transformer up to ~100C for an hour or so, then plunge it into the vanish. The hot air inside the transformer will cool, shrink, and draw the varnish father into the windings than a simple room-temperature dip would accomplish. I try not no vacuum impregnate using a solvent-based varnish, as it tends to boil off the solvent and make a mess.
Old 8th January 2020, 09:00 PM   #16
Good objection!
Best regards!
Old 8th January 2020, 09:21 PM   #17
MorbidFractal is offline MorbidFractal
Best regards!
These days posh fridges suck to close their doors properly and remove internal air/moisture. Don't know what sort of vacuum they achieve but perhaps that is what SemperFi was referring to. I assume it is a unit that is separate to the compressor.
Old 8th January 2020, 09:55 PM   #18
I think you are correct it is the compressor but I use the wrong end which sucks. It does a good job. I mainly use it for composite layups when making parts but have also used it for traffo vacuum impregs.
Lots of info on web regarding diy vacuum pump from old fridges.
Old 9th January 2020, 01:15 AM   #19
PRR is offline PRR  United States
PRR's Avatar
The standard Freon pump in a refrigerator will pull a pretty good vacuum. It is not the greatest vacuum pump around, and may not last long sucking dirty air, but "dead reefers" (switches or wires; often the compressor still works) are nearly free in wealthy countries.
SMPS transformer varnishHide this!Advertise here!
Transformer for 1kW SMPS. elektryk Power Supplies 6 9th January 2015 09:29 AM
Removing transformer varnish db! Equipment & Tools 15 16th December 2013 07:53 PM
smps transformer panos1 Power Supplies 23 26th November 2013 11:16 PM
Using a large 60hz toroid transformer as an SMPS transformer EWorkshop1708 Power Supplies 20 22nd June 2011 09:05 PM
Varnish on old transformer duderduderini Tubes / Valves 12 19th May 2008 02:20 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
