MLCC, FILM or Alu ?
MLCC, FILM or Alu ?
Old 10th January 2020, 01:35 AM   #21
Mark Tillotson is online now Mark Tillotson
10uF could be an inductor for the RFI. Self-resonant frequency goes down as capacitance goes up(*), anything in the range 100pF to 10nF is reasonable as an RF decoupling. 10uF is more like audio decoupling.
(*) depends on cap construction though.
Old 10th January 2020, 08:51 AM   #22
altec9440 is offline altec9440
In broadcasting equipments we love to add ceramic/tantalum parts mainly to prevent RF return.
I also understand power distribution where you put caps on each card (extracted from a regulator datasheet : "if the regulator is not in close proximity to the power-supply filter capacitors. 0,1-F or 1-F ceramic or tantalum capacitor provides sufficient bypassing)
Caps are 3 to 6 cm distants from TO3 case on the pcb. Far to help preventing oscillations ?
In this design, I'm considering the use of 0,1uF film after 10000uF aluminium like bandaging a wooden legs.
But I may be wrong ?
Old 10th January 2020, 11:37 AM   #23
Osvaldo de Banfield is online now Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
This approach seems good. At least, when testing, you will able to rectify if a trouble arises.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
MLCC, FILM or Alu ?Hide this!Advertise here!
Is this vishay MLCC good for compensation cap? rhythmsandy Solid State 10 13th December 2016 05:44 PM
MLCC for high voltage decoupling in SMPS phoenix87 Power Supplies 9 14th August 2016 03:21 PM
using MLCC's for critical audio applications roburg Parts 14 19th September 2015 11:39 AM
MLCC vs Silver Mica ksjung88 Construction Tips 7 30th October 2014 12:25 PM
Carbon film vs metal film resistors in a stepped attenuator? G Tubes / Valves 17 22nd August 2004 01:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
