Zero Zone TPA3255 board auxiliary voltage regulator.
Zero Zone TPA3255 board auxiliary voltage regulator. Please consider donating to help us continue to serve you.
Old 4th December 2019, 07:03 PM   #11
FauxFrench is online now FauxFrench  France
Originally Posted by daniboun View Post
Can you show me the choke you are talking about ?
Of course. It is the choke marked with "100" closest to the LM2575 IC. It corresponds to the 330uH choke on the top of page 2 of the LM2575 datasheet: https://www.onsemi.com/pub/Collateral/LM2575-D.PDF
On the board they have put 10uH while 330uH is advised. Quite a difference. 330uH has the marking "331".
Old 5th December 2019, 03:49 AM   #12
Hi Dani,
I understand that my doubt about the Buck choke value is confusing. How come that a board that should just work is stated to have more important flaws?
ON Semi's datasheet ( https://www.onsemi.com/pub/Collateral/LM2575-D.PDF ) has a good explanation about continuous or discontinuous operation on page 17. A 10uH Buck choke should give a rather extreme discontinuous operation. ON Semi has, on page 13, choke selection graphs. For the LM2575-12, with 40V input voltage and a maximum output current near 0.4A, a Buck choke of 1500uH ("H1500") is recommended. Even above the 330uH I mentioned before.
This indicates support to my worry about the 10uH.
Old 5th December 2019, 11:53 AM   #13
daniboun is offline daniboun  France
Originally Posted by FauxFrench View Post
Fine with the local electronics shop.
Even if you put back an LM2575S, you risk blowing that as well, even with less voltage. You need also to change the choke. It is likely that it was the 10uH choke that blew the LM2575S (current overload) and not the voltage.
As soon as I get the LM2575S + LM2575HVS I will let you know here.
As that moment, I wish you could tell me which one I need to provide to my electronical shop so that they can replace it.
Zero Zone TPA3255 board auxiliary voltage regulator.Hide this!Advertise here!
V8 input board recap - re voltage regulator MaccAu Solid State 0 14th January 2015 05:47 AM
FS: T-REG (TUBE VOLTAGE REGULATOR - POPULATED BOARD)) DIYspaceW Swap Meet 17 7th March 2012 09:10 AM
dual voltage regulator, antibump and dc protection board hyperblaster89 Solid State 0 24th February 2012 11:21 PM
Off board MOSFET's & CCS voltage regulator zebra100 Solid State 6 21st July 2010 02:27 AM
Copyright ©1999-2019 diyAudio
