LT3042/3045 LTSpice simulation
Old Yesterday, 10:42 AM   #51
carlmart is offline carlmart  Brazil
Originally Posted by OlegSh View Post
The layouts are really spacious around the regs. The distance between the decoupling caps and the regs is larger than I would like but if it works why not.
Considering the actual parts size, the caps, particularly the more critical output ones, seem to be around 10mm off, which I'm not sure it's not within specs.
Only getting one and checking that with a ruler would answer that.
I'm much concerned about the actual schematic they used, and, as you also raise, how they could get that price to be that low.
Either fakes or a large batch they could get from someone else that sold them for a lower price.
To check the first option only actual measurements can answer that.
In any case, the bet is low to try it to power an actual circuit. Which in my case would be a RIAA preamp.
Old Yesterday, 11:12 AM   #52
LT3081 would need help to improve its PSRR. Input CR(L)C filter comes to mind. Ideally I would think of using a DC-DC converter in front of it which allows for much lower CR(L)C components values to achieve >100dB extra PSRR at the switching frequency. Doing it for 50 or 60 Hz mains frequency requires large capacitance and either relatively big value resistor which increases the voltage drop and lowers efficiency or large size choke.
Yes, that's what I seemed to notice in my LT3081 simulations, which I thought were wrong because they were worst than the ones I had achieved even with a discrete regulator, which I can show you for you to see.
So I thought my implementation is wrong, and why I asked for a working schematic.
Probably you didn't see them, but there are a few threads dealing with remarkable regulators, some even as good or better than the superregulators.
Old Yesterday, 12:20 PM   #53
OlegSh is offline OlegSh
I've seen all these threads dealing with all kinds of regulators but I prefer relative simplicity of the IC based LDO regs.
Old Yesterday, 12:41 PM   #54
Except for the discrete regulator I will use on the power amplifier, some of the others I plan to build and listen to on the RIAA preamps I will be building.
That is a very sensitive circuit, and it's quite likely there are audible differences between the different regulators.
LT3042/3045 LTSpice simulationHide this!Advertise here!
How to do IMD simulation in LTspice!!! nicholas1113 Software Tools 41 28th May 2019 06:29 PM
LTSpice Simulation Problem fasterbyelan Software Tools 8 28th April 2015 08:36 PM
LTspice simulation 8409513 Power Supplies 2 28th May 2012 04:02 PM
About LTSpice Simulation. nicholas1113 Solid State 2 15th November 2009 08:52 AM
LTSpice Simulation template?! ipop07 Software Tools 5 13th May 2009 07:17 PM
Copyright ©1999-2019 diyAudio
