Voltage regulator bypass questions
Old 1st December 2019, 04:36 PM   #31
Abtr is offline Abtr  Netherlands
Originally Posted by jan.didden View Post
Someone *probably* thought that he/she could lower the noise after the regulator further. But trying that it would completely swamp the low output impedance of the regulator. Like, you have a reg with less than 1 ohm Zout, which means the output voltage it is rock-steady with all the variations in load current that happen while amplifying a signal.
Now you place a Very Large resistor in series, wasn't it 4.7 ohms? So if the load current varies, so does the supply voltage, undoing what the regulator was for in the first place.
Then you place some capacitance after that 4.7 ohms. Tat helps for low output impedance but such a cap has easily a larger ESR than the regulator Zout, and especially at higher frequencies ruins it because of parasitic inductance.
Such a capacitor after a regulator (without the R) is not there to lower the regulator Zout but only for stability; the regulator is 'better' than that cap anyway.
So such things as R65 + cap are done by people with enough knowledge to be dangerous ;-)
Jan
Thank you! One more question. In addition to bypassing R65 I'm thinking about removing the caps after R65 and replace them with a single Kemet A750 cap (aluminum propylen) of several hundred uF to improve transient response. Would that be a good idea? Note that the LT3045 regulator board is connected through 10cm long wires to the crossover board's VIN connectors.
Old 2nd December 2019, 08:43 PM   #32
So I bypassed R65 on both crossover boards and it's a major upgrade. Thanks again! It's now easy to 'listen into the music'. Different instruments/tracks can be easily distinguished and overall sound is more alive and involving.
I think I'll leave the output caps (C16 and parallel capacitors) in place for now. I suppose they can't do much (if any) harm in a strictly analogue audio application.
Any thoughts will as always be much appreciated!
Old 3rd December 2019, 08:33 PM   #33
Ow, and bypassing R65 got rid of a slight hum which was audible at max volume without signal.
All in all it really surprises me how much difference a power supply or voltage regulating circuit can make in terms of sound quality!
Thanks for the help!
Old 5th December 2019, 11:39 AM   #34
carlmart is offline carlmart  Brazil
Originally Posted by jackinnj View Post
I thought it might be instructive to put into a picture what PRR and others have related. C3 is "parameter selected" for 1pF or 100nF. All the other values are per the datasheet. (with a little parasitic inductance thrown in for good measure). The dark blue line shows the effect of the additional capacitor -- an additional impedance peak with Q~=2.9, so phase margin is only 18 degrees.
Can you upload the asc file for this simulation?
Thanks!
Old 5th December 2019, 09:13 PM   #35
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Thanks!
I think this is the one.
Old 17th December 2019, 08:35 PM   #36
I finally received an answer from Xkitz to my question about the function of the capacitor stack after R65: Can I replace it by a single low ESR cap? See:
Their answer: "You could try this, but it will likely result in higher noise floor. Parallel caps of different values filter different frequency ranges of noise. This is recommended by the op amp mfgr, TI. It will not oscillate in a power supply application."
They refer to OPA1654 in the diagram below:
Nothing about this in the OPA1654/1652 datasheets..
Old 17th December 2019, 10:08 PM   #37
JeffYoung is online now JeffYoung  Ireland
JeffYoung's Avatar
Wow, I hope that's a case of Chinese whispers between the designer and whoever replied to your email. Otherwise Xkitz don't have a clue what they're doing....
Old 17th December 2019, 10:27 PM   #38
rayma is online now rayma  United States
Originally Posted by Abtr View Post
Can I replace it by a single low ESR cap? "You could try this, but it will likely result in higher noise floor.
TI recommends between 0uF and 1uF for the LM317 output capacitor, and 10uF for the ADJ terminal.
Capacitors after the series resistor R65 will not affect the regulator's transient response, but they can
filter some HF noise. However the parallel capacitor combination likely has an erratic combined impedance,
due to their parasitics. The 4.7R series resistor will degrade the performance of the LM317.
Old 18th December 2019, 03:05 AM   #39
jackinnj's Avatar
Where does TI recommend that? The LM317 will not be stable without an output capacitor, and a 100uF aluminum electrolytic will work fine.
A capacitor on the ADJ pin reduces noise at the expense of transient response. (This TI has pointed out .)
Old 20th December 2019, 02:28 PM   #40
I received a further reply from Xkitz:
"Decoupling caps are required to be placed near every op amp in the system. As I mentioned earlier, different values filter different frequency ranges of noise. The parallel .1uF, 1uF, and 10uF was a recommendation from an old Burr-Brown app note (which I can't find now). Their measurements indicated this resulted in the lowest noise on the outputs of the op amps."
According to the OPA1652/1654 datasheet (p. 24: “applications with noisy or high-impedance power supplies require [low ESR ceramic] decoupling capacitors close to the device pins. In most cases, 0.1-µF capacitors are adequate.” See: http://www.ti.com/lit/ds/symlink/opa1652.pdf)
So with the ultra low noise and low impedance LT3045 based power supply, the decoupling caps at the op amps may not be necessary..
Voltage regulator bypass questionsHide this!Advertise here!
Voltage regulator prefixes and capacitor source questions bblument Parts 20 29th March 2016 12:35 PM
Maida regulator ADJ bypass kacernator Power Supplies 3 19th January 2014 10:26 AM
on chip negative voltage regulator with positive supply voltage gvsrkprasad Power Supplies 3 20th February 2013 03:19 PM
Please help me understand the voltage regulator with external bypass BJT? Fusion916 Solid State 11 15th November 2012 07:59 PM
LR8N3 Regulator -- Bypass the ADJ pin jackinnj Power Supplies 1 10th December 2007 06:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
