Regulated Tube Power Supply Help
Regulated Tube Power Supply Help Please consider donating to help us continue to serve you.
Old 18th November 2019, 12:14 AM   #11
kward is offline kward  United States
Originally Posted by littlerepairshop View Post
The 5AR4 seems to be only pulling 590V instead of 640V, and the screens of the 6L6's are seeing 209V instead of 265V, while the grids have -107V instead of -52V.
What was your voltage reference for those measurements? On the schematic you will notice that 0V is labeled as the voltage on the cathodes of the 6L6 tubes. In other words after the rectifier and 6L6 plates, all voltages listed are relative to the 6L6 cathodes, because the grid and screen voltages are biased up by the voltage on the cathodes (which voltage is user adjustable).
For an accurate (relative to the schematic) reading of those voltages quoted you need to measure with pos meter probe on the point you want to measure and neg meter probe on the 6L6 cathodes.
Now, you may still determine the HV supply isnít working correctly, but you must do the measurements with proper voltage reference first before coming to that conclusion.
Regulated Tube Power Supply HelpHide this!Advertise here!
All-tube regulated power supply judge2005 Power Supplies 26 23rd April 2019 07:04 PM
Tube testing with regulated power supply...need help tasmaniandevil Tubes / Valves 5 4th March 2017 03:10 AM
DHT Tube regulated power supply marcelop Tubes / Valves 3 2nd February 2014 04:30 AM
Question: Tube Regulated Power Supply Tube747 Power Supplies 8 15th April 2013 04:15 PM
Lambda tube regulated power supply Noam Swap Meet 2 20th November 2002 02:58 AM
Copyright ©1999-2019 diyAudio
