Using the LM317 with higher voltages
Old 28th October 2019, 02:25 PM   #11
carlmart is offline carlmart  Brazil
I'm trying to follow certain findings published in The Audio Amateur in the '90s about the impedance curve of regulators. Not many regulators publish that data, Texas does not on the 783, for instance.
Yes, many regulators, like the LT1083, do not have a negative version, so you need to have separate secondaries on the transformers, wiring them after the regulation and using the ground on one regulator as negative output.
But I would like to have an advice on how to implement my regulator with the 317 or 1083 if possible, just warning what would remain unprotected, like short-circuiting the output, which would be quite rare to happen and would allow me to use them.
My main concern is protection for what I am to power with those regulators.
Old 29th October 2019, 01:36 PM   #12
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
The original 1980 Maida regulator or the 21st century Maida are your solutions!
Best regards!
„The ships hung in the sky in much the same way that bricks don't.“
(Douglas Adams)
Old 29th October 2019, 05:26 PM   #13
Exxxxxxtremely complicated!!! I want something simpler but high quality, preferably with a proven regulator like the 317/337.
If I wanted something like the Maida I would go with a Sulzer or Jung high voltage regulator. It would be just a question of finding a high voltage IC, and that would be hard to beat.
Those are proven designs, both technically and audio wise.
Old 29th October 2019, 06:45 PM   #14
rsavas is online now rsavas  Canada
You can't have it both ways.
I do not know why you want to complicate the issue with wanting 'impedance curve of regulators" If you want them, measure them yourself.
What kind of protection?
OVP, use a SCR crowbar.
OCP use a fusible R or an actual fuse in front of or use a current limiting circuit in front of the reg.
Old 30th October 2019, 12:49 PM   #15
The protection I mean is for overvoltage at the output.
Which high voltage IC would anyone suggest to use on a HV Jung/Didden regulator?
Some time ago one was suggested to me, but I forgot which it was.
Old 30th October 2019, 12:55 PM   #16
The only I could find googling was this one:
http://www.ti.com/product/OPA454
But current is too low to be used on a power amp, even in the low current stages.
Neither if it would be a good choice for superregulator.
Old 30th October 2019, 12:56 PM   #17
Show me a " HV Jung/Didden regulator" schematic
I found this HV dual tracker from Pioneer a while ago.
Old 30th October 2019, 02:51 PM   #18
sgrossklass is offline sgrossklass  Germany
These used to be quite common at the time. This one would seem to be high performance (thumbs up for the current source and AC unity gain) but has a few quirks:
1. I wonder why they used a CFP for a pass transistor when there was ample voltage headroom?
2. Also, why this peculiar voltage adjustment setup with one resistor chain for both and an extra pot for symmetry? Most looked more like this (from a Sansui AU-717):
I.e. the the -reg is basically an inverting amplifier with a DC gain of roughly -1 (allowing for a -0.6 V offset, occasionally also provided by a diode so they could use equal resistor values - it's not like utmost precision is required here), based on the +reg doing its own thing.
Old 30th October 2019, 05:44 PM   #19
The Pioneer design was out of the norm for sure, that is why I posted it because I saw it was different and from one of their TOTL models at the time, M-Z1.
I can not answer your ?'s as to why it was done that way, only speculation. Would need to simulate to figure out performance but I will leave that to the op.
This Sansui design was more common for sure. No protection other than fuses. The tracking saved them a zener.
Old 1st November 2019, 05:30 PM   #20
OK, I don't have here the high voltage regulators suggested in The Audio Amateur, as I am not at home.
The ones I was referring to, based on the 3X7 regulators, were used for an Erno Borbely 60W amp mod, and also for a Hafler DH220. Perhaps someone might remember them.
But I was thinking of a different, more sophisticated and more expensive approach: a high current Jung/Didden superregulator.
Some time ago I had also asked here about such a regulator, and Jan Didden had suggested a high voltage opamp that I can't remember which it was.
Looking around for high voltage suitable opamps, the only one I could find was this one:
OPA552PA Texas Instruments | Integrated Circuits (ICs) | DigiKey
Unfortunately I would need a higher voltage chip, as the amp I would use it for would need +/-67v. The OPA552 can only go up to +/-30v, that means +60v should be the maximum input voltage, which would mean less than 55v DC for the output. Am I correct?
It's a pity I never saw a voltage regulators comparison that included the Kit Ryan's regulator used for the Adcom GFA555. Here it's the high current version they used for it, but Nelson Pass used it to regulate the low current stages on his A75 power amp.
Using the LM317 with higher voltagesHide this!Advertise here!
Advantage in designing an amplifier to except higher than average input voltages? shredhead Solid State 10 2nd March 2015 03:26 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 05:28 PM
BOZ off higher voltages? JoeBob Solid State 5 16th December 2002 05:58 AM
BOZ at higher voltages+funky PS anyone? chiggy Pass Labs 3 10th September 2002 02:24 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
Copyright ©1999-2019 diyAudio
