Linear power supply - two windings or linear voltage regulator
Old 20th October 2019, 12:00 PM   #21
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Stretchneck needs more than 1A output current....
It's only audio. Member of the non modular PCB design committee
Old 20th October 2019, 12:36 PM   #22
stretchneck is offline stretchneck  United Kingdom
Thanks - Iíve rechecked the JCAT Femto USB spec and it only needs 5v 1A. So this might work be a great suggestion!
Old 20th October 2019, 01:02 PM   #23
jean-paul's Avatar
Ok these work OK too:
Low Noise LT3042 Linear Regulator Power Supply Board For Amanero XMOS DAC Power | eBay
Cheap, low noise but not short circuit proof. They work Ok with a 7V transformer like the toroid series Talema produces. They have 1.5V dropout because of the PNP pass transistor.
Old 21st October 2019, 04:41 PM   #24
randytsuch is offline randytsuch
A bit I left out in my initial post was that the 78S05 feeds a pair of 2.7V, 360F ultracaps (or supercaps). I'm depending on the caps to take care of any noise from the 78S05 stage.
If I can get away with less than 2A (I think I can but need to measure), then I may try a lower noise reg and see if it makes a difference.
I've started to use PS's based on these huge caps so I can get away with using a simple regulator, vs a superreg.
A drawback to these caps is you have to worry about heat and current draw while charging the caps up. I mounted my 78S05 on a decent size heat sink, and was using a fan to blow air on the heatsink while the cap charged.
Randy
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Linear power supply - two windings or linear voltage regulatorHide this!Advertise here!
Linear power supply voltage too high whiskypeak Power Supplies 17 10th May 2019 02:38 PM
Power rating for short circuit protection in linear voltage regulator Fusion916 Solid State 5 16th November 2012 10:20 PM
the best design for a <15A linear regulator for solar power supply PinkNoiser Power Supplies 4 22nd June 2012 11:21 PM
48v - 9v linear voltage regulator recommendation? TheFixer Parts 12 6th September 2011 06:11 AM
Low Noise Linear regulator power supply leonm12 Power Supplies 13 13th June 2011 04:50 PM
Copyright ©1999-2019 diyAudio
