Help me Replace capacitors Harman Kardon CA240
Dear friends, I write from Italy (Venice) and I'm new in this forum.
I need help!
I have a Car Power Amplifier Harman Kardon CA240 and I need to replace all the capacitors, expecially power supply capacitors 3000uF and 2200uf.
Someone can help me to suggest which model to use?
Looking on google seems that Panasonic Serie FC or M are good (FC seems better than M) and also Nichicon series UKW and UFW.
Who can help me?
Best Regards
Luca
Moderator
Joined 2011
Ok,
so if original capacitor is 3300uF / 35V , 85° ...
between Current Riple 3.68A and 1.7A I choose 3.68A
and between lost current 1,3mA and 0,003A I choose 0,003A
Confirm?
Yes for the ripple current, but don't worry about the leakage current, which is not important here.
Higher voltage and/or higher temperature is much more important than leakage in this case.
However, 1.3mA is better (lower leakage) than .003A.
