Isotek not using MOVs instead of using VDR which VDR is recommended?
Old 17th September 2019, 04:49 AM   #1
rhythmsandy is offline rhythmsandy
Default Isotek not using MOVs instead of using VDR which VDR is recommended?
Planning to build a power filter system with surge protection but what many use is MOV across mains phase and Neutral but Isotek says using MOV will degrade sound quality and infact when I have tested with noise sniffer from a brand I saw that noise is quite high even with large common mode choke and with x2 and y2 capacitors. Can anyone tell me which VDR does isotek uses?
Old 17th September 2019, 08:03 AM   #2
Elvee is online now Elvee  Belgium
Elvee's Avatar
MOV= Metal Oxide Varistor
VDR= Voltage Dependent Resistor
VDR is a generic term, and could include older types, based on carborundum for example, but nowadays, the only variety you can buy is metal (Zinc) oxide
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophoneİ ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Isotek not using MOVs instead of using VDR which VDR is recommended?Hide this!Advertise here!
IsoTek GII Optimum Fig.8 Cables mainscablesrus Mains Cables R Us 0 5th January 2017 05:49 PM
IsoTek Power Lead Clearance mainscablesrus Mains Cables R Us 1 24th January 2016 08:51 PM
Isotek reccomended for break in? LeMoNFuZzY Full Range 7 15th March 2015 03:25 PM
Anyone try the IsoTek CD free with Hi-Fi Choice? Bas Horneman Everything Else 1 3rd October 2011 07:35 AM
Which is better Denson DeMagic or Isotek System Enhancing CD ??? Im Sparticus Digital Source 2 31st July 2005 08:32 AM
Copyright ©1999-2019 diyAudio
