Safety. on grounding a balanced trafo.
Old 16th September 2019, 04:22 PM   #1
phi112358 is offline phi112358
phi112358's Avatar
Default Safety. on grounding a balanced trafo.
Trafo has 2 inputs and 3 outputs. Case is steel.
Outputs: +6v, -6v, and neutral. It is balanced.
Trafo will connect to an a regulator.
My options I have comeup with:
  1. Connect ground (N wire from mains) to enclosure
  2. Connect 0v output from balanced trafo to enclosure
  3. Shield the 0v trafo output wire from enclosure
  • the trafo is 6v+, 0 6v- outout. 1A curent max
  • 2 wire input (N and live)
How do I make the thing safe?
I know which is N and which is live for 220v mains input
The case is covered in nonconductive paint but has shielding connections on the inside.
I need a person knoledgable about balanced trafos to answer this question.
I have a fewmore questions but will be grateful to anyone who can answer the questions above or provide a simple explaination about how to make this work.
Thanks,
Movin on up!
Old 16th September 2019, 04:41 PM   #2
Mark Whitney is online now Mark Whitney  Netherlands
Mark Whitney's Avatar
Never connect N to the chassis! Treat it as of it is live.
From the mains you only connect PE to the chassis.
Regards Mark.
Old 16th September 2019, 04:52 PM   #3
rayma is online now rayma  United States
+++++++++1000
Old 16th September 2019, 05:04 PM   #4
DF96 is offline DF96  England
A metal case but no ground means double insulation is necessary for safety.
Old 16th September 2019, 05:31 PM   #5
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Safety. on grounding a balanced trafo.
3 pin iec socket, wire L and N to traffo, wire gnd from ice socket to electrically conductive point on chassis.
Sounds like a 0v centertap transformer rather than a balanced unit which is typically a 1:1 ratio unit.
Old 16th September 2019, 06:15 PM   #6
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
And in any case a "trafo" never has
6v+, 0 6v-
outputs.
It either has 6VAC+6VAC or 12VAC center tapper or it is not a "trafo" but a Power Supply.
If itīs 2 wire mains itīs either very old when that was the norm or very modern, double insulated, where it does not actually *need* a third Ground wire.
Clearly describe which of these applies, because it is VERY important and changes suggestions considerably.
State brand and model and if possible add a picture.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 19th September 2019, 08:21 AM   #7
phi112358's Avatar
I had a suspicion about that, connecting the neutral output to the case. There are 2 wires going in and 3 coming out. It is an E and L henry trafo from thailand. So Luckilyy my new apartment has ground wires on the mains along with live and neutral.Will utilize that ground wire. Should Ijust put electrical tape over the live part of the 0v wire coming out? (there are 3 wires coming out, both +6V & -6V, then sero. Seeems I should just cover the zero output wire in electricaltapefrom allthe advice I(think) I interpreted correctly.
Old 19th September 2019, 08:25 AM   #8
phi112358's Avatar
Default Ahh,makes sense
yes it is a 0v centertap trafo.
Must be.
Old 19th September 2019, 08:38 AM   #9
phi112358's Avatar
Originally Posted by JMFahey View Post
And in any case a "trafo" never has outputs.
It is an E and l Henry trafo and it is wound so the middle of the secondary comes out as one of the 3 secondary wires (or more specifically the V of the center tap of the secondary comes out as halfway between the V of the two outer secondary terminals. One of the three secondary outputs is actually just the center of the wire which forms the secondary side of the trafo. I have taken one apart before to check out how it was constructed . Primary has only 2 inputs. connect the AC meter from center wire to either of the two other secondary outputs and it reads 6v. Yes it is AC so there really isn't a + and a- but if you connect the meter between both outer wires, it reads something like 12v. I have used these for years, surely unloaded it reads a bit higher. That is the gist of the unit
It is not a normal shaped trafo.The primart and secondary each occupy one seperate half of the trafo. It is not wound in layers but in discrete halves.
Old 19th September 2019, 08:32 PM   #10
TBTL is offline TBTL  Germany
Do the specifications of the transformer explicitly mention 'double insulated' or 'Class II'? If not, assume that it isn't, so the metal case must be connected to safety ground.
Safety. on grounding a balanced trafo.Hide this!Advertise here!
Need safety advice on grounding HiFiNutNut Power Supplies 11 20th October 2018 11:47 PM
Phono Preamplifier Grounding Scheme for Low Hum, Noise + Safety spaceistheplace Analogue Source 4 2nd May 2017 10:45 AM
Question regarding 3rd wire grounding and safety Bitrex Tubes / Valves 1 12th February 2009 05:36 PM
Copyright ©1999-2019 diyAudio
