A cheap SMPS for audio on ebay
Old 17th September 2019, 10:42 AM   #11
ginetto61 is offline ginetto61  Italy
Originally Posted by KVP View Post
I have 1 (in fact 2 of them) - the first that arrived caught fire when connecting to mains.
I contacted seller which didn't discus and I received a second one.
It works pretty well, although initial voltage without load connected to it is quite high (appox. 4 volt above what is indicated).
Can't comment though about safety
Hi thanks for the helpful information.
May i ask in which design are you using it ?
my curiosity started by noticing how rare are smps in audio amplifiers. Given that, i guess, a linear power supply is the most expensive part in an amp ... i do not understand why they are so rare.
Or maybe a very good one will have a price comparable to that one of a linear of same power ? so that there is no savings in the end ? i do not know.
I like very much their compactness and little weight ... the modular construction.
Thank you very much indeed
Kind regards,
gino
Old 17th September 2019, 11:13 AM   #12
adrianbaugh is offline adrianbaugh  United Kingdom
SMPS is inherently somewhat noisier than a linear supply and depending on SMPS design the switching noise can be in the audible range (or have artefacts there). Whether that results in audible noise depends also on what you're powering with it. If noise on the rails is going to get through to the output, then you either need a very good SMPS, very good filtering or a linear supply. On the other hand, other amplifiers have very good power supply rejection - the Modulus86 amplifier discussed on this forum has exceptionally good noise figures but the designer states (and can back up with measurements) that a reasonable SMPS is no problem.
Gyraf G9 || Tubelab SSE || Fostex FE126En in hybrid back loaded horn / bass reflex enclosure || Digital source (Volumio / RPi2 / Pi2Design 502DAC-Pro / Balanced Output board) || Stereo Modulus-86 based power amp
Old 17th September 2019, 11:59 AM   #13
Hi thank you very much ... i feel like i have open a can with some worms inside ... ok The fact that they are actually so rare should have told me something. Then back to linear immediately.
Thanks a lot again.
Kind regards,
gino
Old 17th September 2019, 01:02 PM   #14
amplidude is offline amplidude  Denmark
Heard good things about smps principle called LLC it modulates with wine wave, should be the best for audio purposes
Old 17th September 2019, 02:15 PM   #15
russc is offline russc  England
.... the first that arrived caught fire when connecting to mains...... Can't comment though about safety.
I think you already have!
Old 18th September 2019, 01:21 PM   #16
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Well, I've made the experience that if I modulate myself with waves of wine almost anything improves .
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
A cheap SMPS for audio on ebayHide this!Advertise here!
Amplifier SMPS on eBay ... any experience? Baldin Power Supplies 34 10th February 2019 03:07 PM
Fear and Loathing? Ebay SMPS Chris888 Power Supplies 0 11th October 2017 03:40 PM
eBay 800W +/- 50V SMPS PSU, anyone tried this? shanghai2004 Power Supplies 3 20th February 2016 06:42 PM
Cheap cambridge audio 640C and 640A at Ebay uk pickup only HONITON, Devon UK lduarte1973 Digital Source 0 31st October 2011 11:58 PM
smps on ebay jesserparker Chip Amps 6 12th January 2007 08:46 PM
Copyright ©1999-2019 diyAudio
