Power transformers, winding order
Old 11th September 2019, 05:17 PM   #1
xavirom is offline xavirom  Argentina
Question Power transformers, winding order
Hi. When I learned to calculate and build transformers with an iron core, I did it assuming that the primary winding is the one that coils first, that is, near the core, and the secondary windings, above the primary. I have also seen and built other windings in halves. Recently I discovered that a large number of amplifiers (Technics, JVC, Toshiba, etc.) first build the secondary and on top of it, the primary. Does this have any advantages or disadvantages that windings the other way?
Primary = line input
Secondary = useful output
Old 11th September 2019, 05:18 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
It has been done so to comply with class 2 or double insulation directives.
Saludos, loco!
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 11th September 2019, 06:54 PM   #3
Thanks.
Saludos, amegu!
Old 11th September 2019, 07:09 PM   #4
Where (What zone) are you? Me now in CABA (Job) but I live in GBA (Almirante Brown). You?
Old 11th September 2019, 07:48 PM   #5
Rosario, Santa Fe
Old 11th September 2019, 08:14 PM   #6
OK, rosarigasino.
Separating the primary and secondary wine leakage inductance bigger but capacitive coupling lower. This increase the isolation between windings but decrease the electrical performance of the trafo. But in some instances it is mandatory the use of such a transformers.
Old 11th September 2019, 08:28 PM   #7
Si, jaja..
Thanks for information.
Old 12th September 2019, 01:59 AM   #8
PRR is online now PRR  United States
PRR's Avatar
To a first approximation, it does not matter. ALL the turns are 99+% coupled together.
In some work, it is expedient to wind the primary (a standard design) ahead of time, and then wind a secondary to the customer's need.
In practice, some plans work better than others. Primary is usually thin wire. Bending FAT (how-V high current) secondary wire around fine-wire winding is liable to crush and cut the fine wire winding. Starting with the fat wire you have solid support from bobbin or mandrel, you can lay the fat wire tight and leave good support for the fine secondary. OTOH a high-voltage winding (for tubes) might lay better when put on last. Of course all influenced by operator preference and how much fishpaper can be laid between windings.
Old 12th September 2019, 03:09 AM   #9
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i have repaired a lot of japanese audio amplifiers and the way they did their traffos was to use bobbins that you can actually separate the primary coils from the secondary coils, each with its own coils forms...
this i would say is a very neat way to convert from the 100 volt japanese standard line voltage to the 230 volt standard in my country..
and the good thing is that the secondary is left untouched....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 12th September 2019, 03:15 AM   #10
TonyTecson's Avatar
when doing traffos with dual bay bobbins, then it does not matter which coils to wind first...
Power transformers, winding orderHide this!Advertise here!
Winding Your Own Transformers tmblack Power Supplies 14 20th May 2016 12:06 AM
Tutorial: Compute the relative power of each winding in a multi-winding transformer Elvee Power Supplies 6 20th December 2013 05:43 PM
NICE; Custom 250VA Toroidal Power Transformers; 34vac/7a, plus an Auxiliary Winding dozer Swap Meet 0 19th January 2009 10:10 AM
Comments Please: Winding own audio power transformers UncleJessie Solid State 10 10th August 2003 12:28 AM
Copyright ©1999-2019 diyAudio
