Cheap, variable, dual rail supply for amp testing?
Old 13th September 2019, 08:07 PM   #11
Rallyfinnen is offline Rallyfinnen  Sweden
Thank you for the tip!
Old 13th September 2019, 09:22 PM   #12
sasha70 is offline sasha70  United Kingdom
Hi, I have seen a few good review about this DC to DC converter.
DPS5015 DC 50V 15A Regulated Parts Digital LCD Display Power Module Step Down | eBay
Best regards.
Sasha.
Old 16th September 2019, 06:27 PM   #13
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
Originally Posted by Rallyfinnen View Post
Variac would be nice, but kind of fall out of the cheap-category..
Keep your eye out for a used variac, as itís exactly what you need.
Old 26th September 2019, 07:25 AM   #14
Originally Posted by ubergeeknz View Post
I hope they work out but they do look like they're designed for eg. Battery charging where there's a steady draw, and may not limit current instantly, in the way you would like. I'd test one into a dead short or a small value load resistor with a low current set and see what it actually does before trying to use it. My 2c.
I received the boards and tested this with a 5ohm resistor, and it seems fine. Delay varies depending on the set current limit vs actual current, 10-30ms delay with the settings I tested. I think a fuse would not do better.
Ripple seems ok too. Maybe something I could use instead of a massive capacitor bank on a class a amp..
Old 27th September 2019, 10:49 AM   #15
zjjwwa is offline zjjwwa  Poland
zjjwwa's Avatar
How about something linear, with traditional transformer?
A voltage source / current source?
Any good designs with precision voltage setting between 2V - 60V
and with the possibility of fallback into current limiting mode, 0 - 5 A,
but with this current limiting mode also with precision setting capability,
so that it could also be used as a "current source"?
... In view of the fairly cheap readily abundant readily available Chinese universal laboratory voltage power supplies, does it make any sense to considering building one by oneself?
Old 28th September 2019, 01:33 PM   #16
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Most of the Antec transformers have dual primary and dual secondary windings. Two such transformers can provide a multiplicity of configurations satisfying most power amplifier supply rails by putting the primary in parallel or series.
For power amplifiers, regulated supply isn't necessarily good for testing output stages -- the regulator can put its own signature on the supply rails.
Me, I have a big Variac bought from a fella who used it to power up his air conditioner when Jersey Central Power and Light had one of its frequent brown-outs.
Cheap, variable, dual rail supply for amp testing?Hide this!Advertise here!
Dual rail PWM supply for car audio uzernaam Power Supplies 2 31st August 2018 05:17 AM
Cheap Dual Variable Power Supply ? jacques antoine Power Supplies 16 21st October 2017 04:40 PM
Dual rail supply help surfstu Power Supplies 1 10th May 2016 03:16 AM
Dual rail supply, no centre tap leonrocks Power Supplies 27 14th February 2015 02:31 PM
Can't Tell if Power Supply is Dual Rail Sh00pus Power Supplies 3 29th April 2013 12:21 AM
Copyright ©1999-2019 diyAudio
