PS for linestage tube pre-amp (12b4)
Old 11th September 2019, 11:26 AM   #11
Mark Tillotson is offline Mark Tillotson
Originally Posted by rayma View Post
Total Pd in the resistor is more like 2W due to ripple drop. Remember, that's being removed from the regulator to a cheap resistor. Then I'd use 10R 5W (or 10W if there's room).
On the other hand the regulator's already going to have to be on a large heatsink,
its simpler and cooler to just make that heatsink a bit larger than having a separate power resistor. But such a resistor will reduce the inrush current at startup, that might be important.
Old 15th September 2019, 04:11 AM   #12
john_tracy is offline john_tracy  United States
If you really are dropping 10V@1.2A across the regulator, that's 12W. That will require a fairly big heat sink. Consider connecting filaments in series and drop ~4V@0.6A, 2.4W. A little more voltage headroom could be squeezed out by using schottky diodes with less forward voltage drop.
"It is better to remain silent and thought a fool, then speak and remove all doubt." A. Lincoln
PS for linestage tube pre-amp (12b4)Hide this!Advertise here!
12B4 Linestage Woes Doug R Tubes / Valves 16 14th September 2012 03:33 PM
CCS for 12B4 linestage 240z4u Tubes / Valves 8 24th October 2007 10:11 PM
12b4 vs. aikido linestage Klimon Tubes / Valves 2 14th August 2007 11:38 AM
12B4-A Linestage sorenj07 Tubes / Valves 51 12th February 2007 02:29 AM
12B4 versus 6S4 for linestage rcavictim Tubes / Valves 4 4th December 2005 08:22 AM
Copyright ©1999-2019 diyAudio
