Cancellator: a magic active CM noise canceller to upgrade any brick or module SMPS
Old 20th September 2019, 02:24 AM   #31
PRR is offline PRR  United States
PRR's Avatar
> PME acronym, I am not familiar with this particular naming
I think some of these fine distinctions, you have to go in the box or up the pole/down the manhole to appreciation the differences.
Earthing system - Wikipedia
"PME" seems to be UK jargon. Depending exactly where the splices go, it seems to be "similar" to how we try to do it in Maine (in the whole USA). There's a dirt-rod on the power poles, there's a dirt-rod at the house(?), and part of the feeder is combined N/G (PE) function.
Oh, I suppose the US way is more like TN-C: N and G are not split until the main fusebox, "Consumer". (And most homes are '2-phase' not 3-phase.)
The main difference seems to be: in some systems the consumer gets Dirt-Rod (Ground, PE) ONLY from the company, in others there is a dirt-rod at the customer. In almost all cases the company is full of dirt-rods. In a system with Multiple Earths, the ground currents can be unpredictable.
This may matter to amateur radio which can really depend on ground currents to launch longer wavelengths. It shouldn't have a large effect on a domestic hi-fi.
Cancellator: a magic active CM noise canceller to upgrade any brick or module SMPSHide this!Advertise here!
D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based V.Reg. Elvee Power Supplies 344 Today 01:10 PM
laptop brick SMPS grounding question BeardyWan Power Supplies 13 24th January 2018 07:10 PM
LCD brick causing noise over speakers Ramie Solid State 0 17th February 2015 08:43 PM
A 'brick wall' filter for the +DC rail of a SMPS? andyr Power Supplies 74 21st December 2014 05:24 PM
PSU upgrade for DAC Magic Plus E30NA Digital Line Level 8 1st October 2014 01:00 PM
Copyright ©1999-2019 diyAudio
