Uncommon tests on a batch of 5U4G / 5AS4
Old 12th August 2019, 11:15 AM   #1
trobbins is offline trobbins  Australia
trobbins's Avatar
Default Uncommon tests on a batch of 5U4G / 5AS4
I lucked on a batch of 33 5U4G / 5AS4 rectifier valves a few years ago. 75% of those were made by AWV (Radiotron ala Radio Designers Handbook), and helped confirm the date-coding used by AWV in a thread last year:
AWV local valve dating - 5AS4 and 6DQ6A at least
Although I haven't put these valve diodes to work in amps, they have kept giving - by way of doing some uncommon tests. None of these valves are known to be NOS - there useage history is uncertain.
Firstly, I tested them all in a 500VDC output power supply to confirm no abnormal behaviour. 4 were bad, so they got separated.
One uncommon test is to measure for imbalance of plate-cathode current. I used three constant plate-cathode voltages (24Vdc, 36Vdc, 49Vdc) to measure diode conduction current. Most valves showed good balance between the two diodes, with only a few having one diode conduct less than 80% of the current of the other diode (for the same applied voltage). 40% of the sample showed at least 90% balanced conduction. Below is a plot for the 29 samples tested, showing the % balance in plate currents.
Does unbalance mean anything? Well not really anything that is noticeable, unless imbalance gets worse with age, or shows a higher level of sag for increased loading. A spectrum analyser may be able to show some mains frequency versus 2nd harmonic hum difference, but it is likely just academic in this modern age of large value capacitors.
Another uncommon test was to measure PIV leakage current, by using a modern Insulation Resistance meter (ie. megger). I connected my handheld digital QM-1492 megohmmeter between each plate and heater/cathode in turn to measure IR (insulation resistance). These diodes have a nominal 1,550 volt PIV, and the megger can test at up to 1kV and measure lower than 2,000 Megohm (ie. 0.5 microamp). 14 of 28 valves showed IR > 2 Gigohm for both anodes, both initially when cold, and after the heater was on for a while. 5 valves showed both diodes with a relatively low IR (eg. < 100 Megohm). 3 valves initially showed some measureable IR, but IR then recovered to > 2G when heaters were powered - one valve showed the opposite effect. 5 valves showed one diode with IR > 2G, but the other with a measureable level.
One likely leakage path is from filament vapour deposition on to mica, especially if only one diode has low IR. On a few samples I tested, the IR value increased with lower test voltage (ie. leakage resistance is not constant). I haven't yet seen a manufacturing rejection/pass test for a typical power diode, so not too sure what level of leakage would have been accepted at the factory.
This IR testing does indicate that even a simple 1kV megger can show up suspect valve diodes, although a diode may need to show quite a low IR for it to be a problem in a power supply. A diode with low IR may also be more prone to initial arcing (ie. when PIV is max).
I'm hoping to extend the test voltage up to 1.6kV, still using the 1kV megohmmeter, but adding in a 600V power supply in series. Given the measured increase in leakage current seen from increasing the test voltage from 250 to 500 to 1kV, it will be interesting to see how many of the 14 valves with > 2 G at 1kV still show > 2G at 1.6kV.
Ciao, Tim
Old 15th August 2019, 04:48 AM   #2
trobbins's Avatar
I tested 13 valves that showed no leakage at 1kV, at 1.5kV PIV continuous.
7 showed no leakage. 1 showed just a bit of leakage in one diode, 4 showed at least one diode with no more than 3uA, and 1 showed more than 30uA in one diode.
Unless you have access to a nice megger with >1kVDC test, then it is a bit more difficult to test most valve rectifiers at their PIV. I used a 500Vdc low current supply to add to the 1kV of the megger to apply 1.5kV.
Just setting up for a test to get a feel for the peak heater current at turn-on, and variance in actual heater current for this batch of rectifier valves. Then I want to check out if an NTC thermistor in the heater loop can practically extend the B+ rise time for both direct and indirectly heated rectifier valves.
Uncommon tests on a batch of 5U4G / 5AS4Hide this!Advertise here!
GG preamp, why is it uncommon? geezertron Tubes / Valves 22 20th January 2018 10:25 AM
Uncommon Ground Problem sled Digital Source 6 8th April 2014 10:16 AM
HiFi Fanatic - Uncommon ODougbo Everything Else 0 26th November 2012 08:58 AM
5AS4 sub for 5U4 gingertube Tubes / Valves 6 10th March 2005 08:35 AM
Possible damage of a 5AS4 full-wave rect... Layberinthius Tubes / Valves 2 1st February 2004 08:39 AM
Copyright ©1999-2019 diyAudio
