Help to ID power supply jack - Swiss?
Old 8th August 2019, 04:19 AM   #1
lawdogg is offline lawdogg
Default Help to ID power supply jack - Swiss?
I am trying to figure out what kind of connector this is. (See attached pic)
It's about 6mm I.D. with two pins, which are offset from center.
It's supposed to carry +/- 24V DC. I don't have the original power supply. So I either need to find the matching male plug (and a 24V DC power supply attached to it ), or replace the jack with something more common so I can run a more common 24V power supply, unregulated wall wort is OK.
Thanks in advance for any help.
(I've been looking around online for a few days now and found nothing - just some good reference pages that refer to many types of connectors but not this one, e.g. Common plugs and connectors - Helpful)
Old 8th August 2019, 09:25 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
It is called an aviation connector. Many sizes and pin configurations are available.
aviation connector - Google Search
Aviation connector 2 pole O10mm - Audiophonics
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Last edited by JonSnell Electronic; 8th August 2019 at 09:27 AM. Reason: Examples ...
Old 8th August 2019, 05:34 PM   #3
Thanks - looks like all the 2-pin aviation jacks put the pins right down the middle.
However, it looks like a 3-pin male plug may potentially place two pins at an offset - just not sure if it's the correct offset. Maybe I should buy one to see.
Old 8th August 2019, 07:31 PM   #4
Hmm these aviation connectors actually look way too big. Will see if I can hunt for a smaller one.
This is showing an M16 size ... but I need the male connector to fit into a 6mm opening. And my plug is not threaded.
Old 8th August 2019, 10:00 PM   #5
What I mean is (and I can't edit my post), the plug IS threaded - just not to the end. The thread size TBD. It is not threaded all the way to the end, is what I meant.
I took a straight-on cell picture and noted the 6mm I.D. here. In so doing I discovered an icon of some kind in the middle of the connector - a clue?
You can also see the offset of the pins from this pic.
Old 8th August 2019, 11:41 PM   #6
MAAC0 is offline MAAC0  Portugal
There is indeed a smaller version... like those fitted on mic bodypacks. I use one for powering a Behringer mixer.
Old 9th August 2019, 12:22 AM   #7
Thanks, looks like the M6 size is about right although if I was smart I'd figure out what thread this is.
Was looking at this for example: WEIPU SF6 6mm 4Pin Waterproof IP67 Cable Connector,Power Aviation Connector 676422916160 | eBay
It is almost right but a little too big ... the O.D. of my connector is ~6.8mm.
(I realize I won't be able to edit this in the future so apologies in advance when that link dies - edit, while I still can edit this, I'll upload the screen shots as attachments.)
Just to confirm - the two pins are offset from center on yours?
It sure would be easier if an actual store carried these things so I could go look ... I wonder if Fry's does.
Old 9th August 2019, 03:26 AM   #8
Indiglo is offline Indiglo  Australia
Does that look like the Binder Connector Logo ?
Could be a 711 or 712 M9 series connector ?
Old 9th August 2019, 03:44 AM   #9
GREAT SCOTT
Cable plug connector - M9 IP40 - Subminiature Circular Connectors - Products | binder USA
And my MS paint comparisons attached ... I think we have a winner (assuming the diameter matches ... I think it does so far...)
Old 9th August 2019, 04:32 AM   #10
Have confirmed that my thread O.D. is about 8.9Xmm which is correct for M9 thread. This is the thread that this connector has.
Female cable connector - M9 IP40 - Subminiature Circular Connectors - Products | binder USA
I think I shall order one.
Help to ID power supply jack - Swiss?Hide this!Advertise here!
Banana plug jack or RCA jack chassis mounted Hextejas Construction Tips 6 28th September 2018 08:56 PM
Wire DC Power Jack for 9V Battery BubbaGump Power Supplies 2 28th May 2010 03:40 AM
2 Mono Jack to Female Stereo Jack JellyMan Everything Else 2 27th May 2008 03:39 PM
where to buy iec power jack with switch and fuse neil_kaye Parts 3 5th January 2007 12:37 AM
dc power jack for wah shell? space-cake Instruments and Amps 1 13th October 2006 05:06 AM
Copyright ©1999-2019 diyAudio
