Ground check
Ground check
Old 7th August 2019, 05:37 PM   #1
potstip is offline potstip  Turkey
Default Ground check
Have proper ground is very important especially for class a power supply CRC / CLC design. So is there anybody know a circuit to test if ac ground is ok or not. If not ok do not let start up and gives an error with led or any if it is ok power mains troidal transformer.
Old 7th August 2019, 06:17 PM   #2
craigtone is offline craigtone  United States
craigtone's Avatar
The only purpose for AC ground is safety. Whether it connects to the signal ground is completely up to the designer if they choose to do single-point ground with it connected or put in a ground lift circuit.
If you do still care to do this, you could purchase a cheap AC outlet checker that checks for open ground and use the open ground LED output as a way to disable a time delay power-on relay.
https://www.homedepot.com/p/Power-Ge...E&gclsrc=aw.ds
Craigtone Audio
Soundsmith Boheme, WT Classic, Pearl 2, Apollo-R, Burson Swing, Hafler 915, TSE 45, ALK Klipschorns
Old 8th August 2019, 10:54 AM   #3
DF96 is offline DF96  England
Yes, it seems that two quite different concepts are being confused.
The incoming AC ground is all about safety.
The proper grounding of a PSU and the audio circuits it supplies are all about reducing hum and noise.
It is unfortunate that the same word is used for these two quite different issues, but it is probably too late to invent new words to help distinguish the difference.
Old 8th August 2019, 01:46 PM   #4
Max Headroom is offline Max Headroom  Australia
Max Headroom's Avatar
Location: West Australia, near to the beach, natural ambient sounds mostly.
AC Socket Checker
This schematic will indicate that AC wall sockets wiring is correct and could be built inside the amplifier.
Amplifier internal supplies local ground should be connected to cabinet/PE connection.
Dan.
Ground checkHide this!Advertise here!
connecting dual differential output ground to single ground connection Qualitysound Class D 4 24th April 2019 04:36 PM
Vintage Harman Kardon amp ground loop issues - 2 prong plug w/floating ground ThatDavid Solid State 16 22nd February 2019 08:04 AM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 03:50 PM
how do you check to see if your ground is bad inside of your amp? flakdogg Solid State 0 22nd March 2004 03:23 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Copyright ©1999-2019 diyAudio
