calculation of resistor value in CR circuit of B+
Old 21st July 2019, 03:13 PM   #1
classicyip is offline classicyip
Default calculation of resistor value in CR circuit of B+
hey folks, I wanna ask for advice.
Let say if I am making a SET of 2A3 driven by 6SH7,
and I wanna make a power supply for both 320V and 180V, using capacitor and resistor circuit to "drop" the 320V to 180V?
how can I accurately calculate the resistor value for it ?
thanks
Old 21st July 2019, 06:36 PM   #2
pinholer is offline pinholer  Canada
Assuming that the 6SH7 is operating in triode mode and the plate current is 10 mA, then using Ohm's Law (R = V / I):
R = (320 - 180) / 0.01= 14 000 or 14k ohms
The operating point of the 6SH7 in your circuit may be different, so you may have to recalculate using your actual operating current.
Old 22nd July 2019, 02:35 AM   #3
thx pinholer, but let say the circuit shown below , the math doesnt work ;
the voltage drop at 6SL7 end is too small if use of the presumed current draw by 6SL7 x tWO 2k2 resistor ........
Old 22nd July 2019, 02:38 AM   #4
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
It does not show up. Better not [IMG] but attach and upload.
Old 22nd July 2019, 03:45 AM   #5
thank you, here is the schematic
Old 22nd July 2019, 04:09 AM   #6
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Why would it?
You ask about:
320V and 180V .... 6SH7 ....
calculation of resistor value in CR circuit of B+-audiomirror6as7pse_v6_psu-2-gif
While your schematic shows:
* NO 6SH7
* NO 320V
* NO 180V
anywhere.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 22nd July 2019, 09:49 AM   #7
DF96 is offline DF96  England
What current draw do you presume for a 6SL7? What has that got to do with your circuit?
calculation of resistor value in CR circuit of B+Hide this!Advertise here!
LM3886 Mute Resistor Calculation Jefferson30 Chip Amps 4 11th June 2015 10:20 PM
Stepped attenuator resistor calculation software pmillett Tubes / Valves 5 13th October 2013 03:27 PM
Bias Circuit Calculation blue andry Tubes / Valves 26 6th July 2010 12:55 AM
GZ34 anode load resistor calculation - help? coolmaster Tubes / Valves 16 3rd February 2007 04:42 AM
Resistor/Voltage calculation Puzzle/woes. Brian Guralnick Everything Else 9 11th February 2006 08:43 AM
Copyright ©1999-2019 diyAudio
