P/Supply board _ Which resistor to change?
Old 19th July 2019, 10:04 PM   #1
gigigirl is offline gigigirl
Default P/Supply board _ Which resistor to change?
Hi Guys, A little help please. I stupidly ordered two of these boards without fully reading the description, Thinking they were adjustable, I need 18 VDC but got the default 5 VDC.
LT1963A LT1963 regulated power supply board for decoding, preamplifier coaxial | eBay
The vendor advises I just need to change the resistors, But can anyone advise what value? Or do I just need to increase or decrease the resistance by trial & error to get it right.
Cheers
File Type: png O1CN01ubbH6U1jgljIv0JtC_!!1135954578.png (546.8 KB, 101 views)
Old 19th July 2019, 10:08 PM   #2
Default Picture of un-populated board
File Type: png O1CN01s9DT6b1jgljLAYshi_!!1135954578.png (323.9 KB, 98 views)
Old 19th July 2019, 10:23 PM   #3
rayma is offline rayma  United States
It's difficult to tell the resistor values on the board, but use
18V = 1.21V x ( 1 + R2/R1 ) .... and then 13.88 x R1 = R2
Keep R2 the same, and decrease R1.
Old 20th July 2019, 01:45 AM   #4
Hi, Thanks rayma I will give that a go.
Cheers
Old 16th September 2019, 05:24 AM   #5
Well finally got around to change the resistors.
Unit works OK, but is not what I would call now noise. Definitely not suitable for phono or dac. Cheers
Old 16th September 2019, 08:38 AM   #6
johnego is offline johnego  Indonesia
Yes, it is not low noise (see picture) but surprisingly it (something based on this chip) was in the fourth place in blind listening comparison just below Jung/Didden, Burson and Sjostrom.
Old 16th September 2019, 08:52 AM   #7
Mooly's Avatar
Have you proved your phono stage to be silent when using a different supply as it is possible the noise is not related to the supply? Have you looked at the regulator outputs on a scope?
Old 16th September 2019, 09:06 AM   #8
Ketje is offline Ketje  Belgium
Ketje's Avatar
Not advisable to use the LT1963 for 18V out. The max input is 20V leaving not much space for a ripple on the rectified DC.
Mona
Old 16th September 2019, 08:38 PM   #9
Hi Guy's, Yes my AD797 Phono Amp is very, very quiet when using SLA batteries.
I was originally planning to use one of these at 18 V, but then they came in a pair to allow +/- operation. So initial test was done at 12 V.
Cheers
P/Supply board _ Which resistor to change?Hide this!Advertise here!
Marantz CD5000 mods leave resistor or change MaccAu Digital Source 12 17th April 2018 10:04 PM
Question about plate load resistor with slight change in value Tubenstein Tubes / Valves 4 17th March 2017 05:43 PM
Change the resistor value in the PS scheme erez1012 Pass Labs 5 19th February 2014 06:43 PM
Resistor to change Qts of 12 inch driver ashok Multi-Way 0 26th May 2007 02:19 AM
Leach amp R37 - R40 resistor change!? supernet Solid State 4 23rd May 2002 12:07 AM
Copyright ©1999-2019 diyAudio
