On & Off noisy DAC
On & Off noisy DAC
Old 2nd July 2019, 01:56 AM   #1
tribute is offline tribute  Australia
Default On & Off noisy DAC
Hi, I have a generally very quiet system, but my DAC a Parasound is always the noisiest. Sometimes it can be quiet noisy and other days quiet, but the rest of my system does not change.
Could I add something like this before the DAC power line to make it quieter.
Audio purification power board improves audio quality for Preamp CD DAC L6-57 | eBay
Or any other suggestions?
Cheers
Old 2nd July 2019, 03:39 PM   #2
Mark Tillotson is offline Mark Tillotson
What sort of noise? How loud is "quiet noisy"? What is connected to it?
Old 6th July 2019, 02:37 AM   #3
Hi, Thanks for the reply. The noise is a Bur,Bur.
Cheers
Old 6th July 2019, 02:44 AM   #4
rayma is offline rayma  United States
This is through the speakers? You could try an external line filter without risk.
Old 6th July 2019, 03:11 AM   #5
kazap is offline kazap
kazap's Avatar
Cheers
To problem solve we need more info as theres no evidence its a power line issue
1.what is the DAC model, how old is the DAC, have you checked the caps, can you upload a photo of the internals
2. what happens on noisy days when you put a different DAC in or use a CDP- is it noisier too on those days or is it fine
3.what is the source for the DAC and on noisy days what happens if you pull the input cables
Old 8th July 2019, 06:35 AM   #6
Default Picture added
Hi Guys, Thanks for the replies
Dac is about 3 to 4 years old, it is a Zdac.
See picture of inside attched.
Cannot try another dac as this is the only one I have, I'm a vinyl man!!
Have not tried pulling the cables as for the last few days it has been quite quiet, but still not as quite as my MC set up. I have quite extensive noise filters, power goes through 2 for the main rig including the Dac
Cheers
Old 9th July 2019, 11:32 AM   #7
kazap's Avatar
With all the power filtering it seems dirty mains power is unlikely? But could you have a ground loop?
Do you feed it bits via copper eg USB/RCA SPDIF? If so when it gets noisy pull the cable and try and feed to optical bits to rule out ground loops via the digital input.
If you like vinyl and DIY you might prefer a DAC with a TDA1541A chip and tubed output.
On & Off noisy DACHide this!Advertise here!
noisy pre amp, audio transformer noisy? Salomon102 Analog Line Level 5 12th August 2015 07:53 PM
Help with a noisy NAD 216 krestudon Solid State 11 17th February 2011 05:12 PM
Noisy ADC 5th element Digital Line Level 6 30th August 2009 10:29 PM
Help with noisy fan artcarmo Solid State 7 9th March 2009 06:34 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 04:07 PM
Copyright ©1999-2019 diyAudio
