High Quality FS (fire safe) resistor and Fuse
Old 23rd June 2019, 12:26 PM   #1
diypass is offline diypass
Default High Quality FS (fire safe) resistor and Fuse
hi guys i need of your usefull help.
i must change components in my PSU with high quality standard replecement:
- two resistor 2.2 ohm 1W FS type
- one fuse T1.6AL/250V
please advise me what brand and specs i must choose on mouser
thanks a lot
Old 23rd June 2019, 02:58 PM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The resistor is a Fire Proof type.
Axial Fixed Resistor 2.2Ω 5% 1W -500 → +350ppm/C[/B]
The fuse is a standard 1.6A 250v Time Delay any preference on size?
1.6A Ceramic Cartridge Fuse, 5 x 20mm, Speed T
1.6A Glass Cartridge Fuse, 6.3 x 32mm, Speed T
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 23rd June 2019, 03:04 PM   #3
do you have any suggestion on brand for high quelity resistor?
i don't understand your question
however the fuse very standard fuse, i want change it with higher quality one
which is the better one between both ?
remember i'll buy on mouser
Old 24th June 2019, 07:27 AM   #4
ok no answer
250V of the fuse is VAC or VDC ?
Old 24th June 2019, 08:32 AM   #5
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
The one that fits to your fuse holder.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 24th June 2019, 08:34 AM   #6
Old 25th June 2019, 12:55 PM   #7
kecapmanis021 is offline kecapmanis021  Indonesia
kecapmanis021's Avatar
Hi, for power supply section you can use Panasonic Erx or Erg. They are metal oxide film resistor with flame proof characteristic. It is important to match old resistor wattage with new replacement. Hope this might help.
As for fuse you need to check the diameter and length of the tube. Then go to Mouser and search for"glass fuse", filter with suitable diameter and length, and "slow blow". They are all standard industrial glass fuse. If you want fancy audiophile fuse then check at Partsconnexion perhaps they have some on offer.
Old 25th June 2019, 12:58 PM   #8
250 VAC
Old 25th June 2019, 01:09 PM   #9
thank you
High Quality FS (fire safe) resistor and FuseHide this!Advertise here!
Why Nchanel gate resistor got fire Myint67 Solid State 4 18th February 2017 11:36 AM
Is this a safe/reliable solution for fuse holder? Hogwild Construction Tips 11 26th May 2016 02:47 PM
New Aleph mosfet source resistor fire astus1836 Pass Labs 2 31st January 2016 10:31 AM
Do I need "high quality" loading resistor? Sunsun22 Analogue Source 19 14th April 2013 10:06 PM
High Quality 5 x 20 mm Fuse Holder ? skibum Parts 2 5th July 2010 01:31 AM
Copyright ©1999-2019 diyAudio
