Class II power supply wiring
Old 14th May 2019, 12:38 PM   #11
xtraforcz is offline xtraforcz
Is primary fuse located in plug bad? I have one C7 power cable with fuse in plug.
Old 14th May 2019, 05:12 PM   #12
Mark Whitney is offline Mark Whitney  Netherlands
Mark Whitney's Avatar
Really bad. What happens if someone uses a different cable?
How high is the maximum current? Is a C7 cable and connector the right choice?
Regards Mark.
Old 14th May 2019, 08:27 PM   #13
Elvee is offline Elvee  Belgium
Elvee's Avatar
If you build something for yourself, regulations are a good base, but don't try to follow them to the letter, like the manufacturers do: they try to comply AND spend a minimal amount of money.
Your main concern should be your safety, and common sense and a good understanding of problems are your best friends.
If in doubt, add a supplementary layer of insulation, and/or ask more experimented people on this forum.
If you try to follow too closely the rules, you run the risk of missing some important safety details.
For a home builder, one additional £, $ or € spent on a project is negligible, and it can make a lot of difference safety-wise, so never hesitate.
. .Circlophone your life !!!! . . ♫♪ My little cheap Circlophone© ♫♪
Electrify your daily life!!! ....⚡⚡ ELEKTRIA ⚡⚡
Old 15th May 2019, 12:09 AM   #14
The connector and cable are right, a C7 cable and a C8 socket. I will include a main fuse then.
Old 15th May 2019, 03:45 AM   #15
Electrical grade silicone are expensive! May I replace with Araldite epoxy resin instead?
Old 15th May 2019, 09:20 PM   #16
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
I don't really think adding silicone or araldite is going to achieve anything. You would probably be better off just adding another layer of heatshrink over the joint.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 15th May 2019, 09:29 PM   #17
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Originally Posted by xtraforcz View Post
Hi all, I am planning to build a lm3886t based amplifier and I prefer Class II electrical wiring, even though many recommends Class I. This is because Class II seems easier to me.
Are you concerned with ground loops through the mains earth?
There may be another way to resolve potential problems and retain protective earth
Old 16th May 2019, 02:19 AM   #18
The objective is to completely cover any live conductive part with best insulation. Maybe a coating of adhesive/sealant between the heatshrink and the iec socket?
I mainly uses portable player like smartphone or ipod as the input source for my amplifier so ground loop is not a concern here. The reason I prefer class II is that I am confident in applying perfect insulation to completely seal the hazardous live conductive path which make designing a safe PE connected circuit a bit redundant.
Class II power supply wiringHide this!Advertise here!
Power Supply Wiring volkatron Power Supplies 3 26th July 2010 03:42 AM
power supply wiring Richidoo Solid State 5 20th November 2006 04:03 PM
Wiring car amp to a benchtop power supply bans27 Everything Else 5 15th March 2006 08:30 AM
Which Wiring For Power Supply InfinityPWS Class D 2 11th March 2005 09:13 AM
aleph power supply wiring Jmertz Pass Labs 5 20th January 2002 04:46 AM
Copyright ©1999-2019 diyAudio
