So I was building myself a little linear psu for my Rpi music player. I have a Schurter pcb mount line filter and when came to wiring it together in realised i was about to solder it in after the 7vAC Talema.
Is this ok or does it need to be in front of it. I know that is is the norm for it to go first but thought I'd ask if it is ok after the trafo.
Thanks for the replies.
The filter I have only has an earth on the load side. Just neutral and live on the line side.
But PE grounding to chassis is PE ground to chassis I guess so any earths would all be common to each other..so with 3 core mains in cable....only 2 cores to line side filter and the earth core to the middle pin of the load side and chassis.
