In linear power supplies, we've often seen mods like snubber diodes, bypass capacitors, zener current sources, faster soft recovery diodes etc.
Are there any well tested mods than can be applied to Switch Mode Power Supplies?
BEAR IN MIND THAT THESE SUPPLIES CAN KILL YOU-they often generate 300-400V
Totally different working principle and any snubbers etc are included. Modifying a professionally designed SMPSU is not necessary or even recommended by people that know how they work.
The only 'mod' could be to improve the power factor, if less than 0.8 or so, by adding power factor correction before the power supply, not during it.
On a totally different tack and depending on the 'quality' of the SMPS I would look over all soldered joints paying particular attention to heavier parts such as wound components and larger semiconductors and would not hesitate to reflow a board that looked as if it might develop issues a few years down the line.
The brand and general look of any electrolytics fitted would determine whether I would replace them as a matter of course with known top quality items, or whether I deem the original choice the manufacturer fitted as being suitable.
I fully agree with the other postings. Unless you really know SMPS design well, don't try to modify ("improve") them. Consider them "black boxes".
One thing you may do, however, is adding low ESR capacitance between the output terminals. A little for a start, if OK more. It may reduce voltage ripple and improve load step response. On the other hand, further capacitance may also bring the SMPS regulation loop to oscillate or have less good dynamic properties, depending on the design of the SMPS.
If not already shielded by a metallic enclosure, put one around it but WATCH OUT FOR PROPER INSULATION DISTANCES!
Yeah Replace the SMPS with a good quality Linear Supply.
You are a jokerYeah Replace the SMPS with a good quality Linear Supply.
- Power Supplies
- SMPS power supply mods?
