L-Adapter
diyAudio Chief Moderator
Joined 2002
Rpi 4 specifies 5.1V 3A PSU. This is 15.3W ability not fully used. At least not all of the time or without heavy peripherals.*
Your Fluke meter shouldn't have gone off scale in Ampere series measuring mode. Maybe there is a shorted or reversed end plug/cable?
Dummy tests for this kind of rail & load range take three 4.7Ω/10W resistors. One pulls 5.1V/4.7Ω=1.085A. Paralleling a second one pulls 2.17A. Paralleling a third one pulls 3.255A.
Those tests aren't sustainable with small on board Q2 heatsink for long. Short time tests only. But if passed without considerable rail dropping and LEDs not extinguishing it means there's no problem with your PSU configuration & parts even for 3A peaks and bit more.
*RPi Power Benchmarks
I've soldered most parts except for a missing IC1 regulator. But I also realized I forgot any thermal pads or paste between the heatsinks and rectifiers/transistor(Q2). I only want to confirm that I really need the thermals, then I will try to arrange it without desoldering...
EDIT: just read the guide again and understand that it is not needed when sinking is done on board. Correct?
