Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#681 | |
#682 |
diyAudio Chief Moderator
Alright, let us know.
#683 |
What fuse should one use in the IEC mains inlet socket please? I'm powering a RPi4 which also powers an external SSD. I'm assuming peaks of not more than 3-4A, so would a 4A fast blow be the best bet here? Thanks.
#684 |
You should choose a slow blow primary side fuse based on your transformer's VA rating. That's not to be blowing the fuse by the transformer's inrush current capability at turn on. Primary current is less than secondary current in a step down transformer.
What is your VA? For 230-240V primary and 50VA use around 600mA slow blow. For 100VA around 1.25A. |
#685 |
Thanks foe explaining that Salas. Yes it's indeed a 50VA - 600mA fuses ordered
#686 |
Sorry for a silly question. But the LM334 has V+, V- and adjust. 3 pins. How shall it be connected?
#687 |
V+ pin to rail, Rset (12R) between R V- pins, V- pin to LEDS.
#688 |
Thanks for fast responce. Another question. If I use other leds, like typical round red 3mm leds with about similar 1,9-2 forward voltage. Is it ok?
#689 |
Should be ok. If they have published specs check their Vf voltage at around 5mA not the usual 20mA nominal value.
#690 |
I just bought a few boards and mini kits from TeaBag. I am looking at building in total 4 psu's. I will start with a 12V version for a RME ADI2 DAC.
Looking at the transformers I see that most have 2 secondaries. Now i found a 100VA toroid with a single 14.5V secondary and 6.9A. I think this would be perfect for a 12V L-adapter. I am also looking for a enclosure with heat sinks. Anything else I need to take into consideration? And would transformers with 2 secondaries be a problem? regards, Harold |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
WTB BIII Adapter (Input U.FL Adapter) | clsidxxl | Swap Meet | 0 | 23rd October 2014 05:05 PM |
Need Help with adapter | huskydawg9 | Multi-Way | 0 | 5th March 2010 05:32 PM |
sot 23-5 to dip 8 adapter | 34281 | Parts | 2 | 24th July 2005 12:37 PM |
New To Site? | Need Help? |
