Possible effects of inexpensive SMPS + linear power supply
Due to limited space, I am thinking to get a small SMPS to power my stepped attenuator (mainly relays, bjts & micro controller). In this case, the SMPS ground will be connect to my analog stage. What would be the disadvantage of this? This inexpensive SMPS takes the input from the mains and outputs 5V. The output will be dirty, full of spikes and HF harmonics...
Poting
AX tech editor
Joined 2002
Poting
Have you considered a SilentSwitcher for your sensitive stuff?
Jan
In that case, a wall-wart would be a great choice. You have the benefit of distance, and putting some common mode cores on the cable will get you pretty clean on interference.
Putting an SMPS in your case probably is the worst you can do....
Jan
Thanks. I will just stick to linear supply then. I was hoping the SMPS could also save me a pair of winding from my trafo.
