Do I need a  step down converter and a Isolated converter
Thread Tools
Old 18th January 2019, 02:05 PM   #1
crisd1 is offline crisd1
Default Do I need a step down converter and a Isolated converter
Hi, I'm new to this so I don't know if this post is in the right place.
I'm trying to make a portable Bluetooth speaker for my school A level project but don't know much about electronics.
So I went on Instructables to find components Ideas. My question is if I need a step down converter and a Isolated converter. Does it not do the same thing? I have. Here is an image of the setup they have used.
Also if you can suggest any better components would be good.
Thanks in advance
Old 18th January 2019, 02:48 PM   #2
Galu is offline Galu  Scotland
Hi! It may be useful if you supply a link to this particular Instructables project.
Old 18th January 2019, 03:12 PM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
99% of step down convertors will also provide mains isolation.
Old 18th January 2019, 03:23 PM   #4
Since this is a battery powered project, I suggest that the converter is there to maintain a steady 5V supply to the bluetooth board even as the batteries run down.
Old 18th January 2019, 04:21 PM   #5
Alternatively:
The isolated converter will galvanically isolate the audio jack from an external power supply plugged into the dc jack.
If 5Vdc and ground are applied to the input pins of the converter, then an isolated 5Vdc and ground is obtained on the output pins.
Old 18th January 2019, 04:26 PM   #6
Here it is: Portable Bluetooth Speaker (FREE PLANS): 9 Steps (with Pictures)
Thanks for the responses
Old 18th January 2019, 04:51 PM   #7
Thanks for the link, which says:
A step-down converter and an isolated converter was used to supply power to the Bluetooth board and eliminate any ground-loop noise.
Eliminating any ground loop noise is in agreement with my last post. Best to include the isolated converter!
P.S. The wiring to the audio jack can't be correct as it would short the left and right outputs to ground. The red wires from the amp should be connected to the right hand sides of the 1K resistors. Good luck with your project!
  Reply to this post
Do I need a  step down converter and a Isolated converterHide this!Advertise here!
Thread Tools
Non-Isolated DC/DC converter tictactoe Power Supplies 2 21st February 2018 04:38 PM
High Voltage isolated DC-DC converter greenocean Power Supplies 1 11th May 2016 11:51 AM
12v-12v, isolated DC DC converter tbj Power Supplies 6 12th November 2013 10:41 AM
DC-DC step up converter? markusA Power Supplies 9 28th October 2010 05:32 PM
DC-DC step-up converter sasha Everything Else 10 1st March 2004 09:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
