I'm looking for ideas to save money for the big caps required for class A SS amps PSU.
Cap multiplier.
SMPS.
Ultracapacitor.
Links to read the pros and cons are highly appreciated.
ALS70A334QS063 | Condensador de aluminio KEMET ALS70A334QS063, 0,33F, +-20%, 63V dc, Montaje en Panel, 5mΩ, 90194 +85degC, Electrolitico | RS Components
Cap multiplier.
SMPS.
Ultracapacitor.
You could start by deciding what ripple you need, and then calculating what cap size you need for the reservoir and smoothers.
Ripple to be ≤ 0.8 mVolts, how can calculate?
Bias +-50V 2.15A
I am sure someone, possibly me, has already told you that in previous threads. Why do you always start from scratch in terms of knowledge for every item you design? Do you never make any notes?
You calculate ripple by calculating the charge lost from the reservoir capacitor (Q=It) during the period between charging pulses, then using the capacitor equation V=Q/C to find the voltage drop.
- Power Supplies
- SS class A amp PSU
