Shunt regulator PSRR dropout?
Old 3rd January 2019, 11:41 PM   #1
JeffYoung is offline JeffYoung  Ireland
JeffYoung's Avatar
Default Shunt regulator PSRR dropout?
I'm looking at a 49V shunt regulator that I've adapted from a design by Pete Millet:
When I run an AC analysis on it, I get an ugly spike at 280kHz where I lose almost 20dB of attenuation:
I can mostly smooth this out by using an ultra-low-impedance electrolytic capacitor for C8. Here's what it looks like with a 0.038 ohm ESR cap:
But that's an awfully specialized cap and it doesn't seem like this circuit should be that finicky. Is there a better way to handle this?
Thanks,
Jeff.
Old 3rd January 2019, 11:56 PM   #2
SemperFi is offline SemperFi  Wake Island
At that frequency an electrolytic isnt much good. >100kHz ltspice cant sim resonances correctly unless u put in all parasitics. Which u cannot know before build. So u cant take it too seriously.
More than 50dB atteuation at that frequency is pretty good.
Old 4th January 2019, 10:56 AM   #3
DF96 is offline DF96  England
Yes. Regulators use feedback loops. Feedback loops have potential HF instabilities, the details of which depend on details of component and layout parasitic capacitances.
Old 4th January 2019, 11:04 AM   #4
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Play with gate stopper value, and put small zobels across the collector Rs.
As DF said, you need to shape the loop gain.
A C across R8/R16 will increase LF PSRR but you may not like that curve visually ;-)
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 4th January 2019, 08:13 PM   #5
JeffYoung's Avatar
I can damp the -52dB spike with either a really big stopper (12K) or a Zobel over the collector resistor. Neither helps the -60dB hump following the spike. Both move the spike to a lower frequency.
Increasing the current through the TL431 moves the spike to a higher frequency.
Dropping the TL431 current to 2.5mA (TI's minimum spec is 1mA) and using a 680ohm gate stopper moves the spike low enough that a more "normal" electrolytic can knock it to -64dB.
Is this worth doing, or is this more likely just SPICE playing with my head?
Thanks,
Jeff.
Old 4th January 2019, 11:51 PM   #6
JeffYoung's Avatar
Here we have:
blue: original
red: stonkin' big 12K gate stopper & higher TL431 current
cyan: original with ultra-low impedance electrolytic (Nichicon UHW)
green: stonkin' big 12K gate stopper with ultra-low impedance electrolytic
Shunt regulator PSRR dropout?-regplot-jpg
Are there any issues with such a big gate stopper? 'Cause the green curve sure looks nice....
Old 5th January 2019, 12:53 AM   #7
JeffYoung's Avatar
I can get basically the same curve by replacing the gate stoppers with Zobels between the gate and drain of the MOSFETs.
Shunt regulator PSRR dropout?-beefcake-shunt-zobel-jpg
Old 5th January 2019, 11:20 AM   #8
Spice can help you see the effect of changing or adding components. What it won't do, unless you tell it, is model the effects of the parasitics of the actual real circuit which you may one day build. At present what you are mainly seeing is the component parasitics included in the Spice models, which will vary a bit from sample to sample anyway.
Old 5th January 2019, 11:34 AM   #9
JeffYoung's Avatar
@DF96, so will the Zobel on average give better results, or are we so far into the weeds that I should just stick with a "normal" gate stopper?
Old 5th January 2019, 11:57 AM   #10
jan.didden's Avatar
Assuming the parasitics of the devices are reasonably modelled, one parasitic to look out for is the C across R27. Try with say 3pF across R27, see what that does to the original, then try again the other things.
The zobel from gate to drain should have exactly the same effect as the same zobel across the collector R.
Jan
Shunt regulator PSRR dropout?Hide this!Advertise here!
LTSpice and discrete regulator PSRR danils Software Tools 21 1st October 2014 03:04 PM
PSRR and Regulator Quality (Lm317 Vs Jung/Didden) Oliphant Power Supplies 40 6th March 2014 09:51 PM
Discrete Zero-Dropout regulator / voltage limiter circuit Power Supplies 9 2nd December 2011 07:12 PM
530V low-ish dropout regulator? dsavitsk Tubes / Valves 5 10th December 2009 04:02 AM
Copyright ©1999-2019 diyAudio
