Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#1781 |
Since I was curious I decided to simulate the LT3042 and ADM7150 with dienoiser and compare it to LM317 and LT3082.
Using the datasheet values for the normal LT3042 config it seems that LM317N+dienoiser has slightly better performance for PSRR in the audio range. The normal LT3042 compared to LT3082+dienoiser has way worse PSRR in the audio range: ![]() As expected the LT3042 with a dienoiser has very good performance, but that could be beat by adding a simple cap multiplier in front of the LT3082 + dienoiser. Sure you could add a cap multiplier in front of the LT3042 as well and get even better performance. Thing is a sot23/sot223 based cap multiplier is still easier to solder and implement than LT3042. Mouser BOM for the whole cap multiplier is 1.5$. SOT223 LT3082 is 3.8$. Total still 0.4$ cheaper than a LT3042. There's also other things to consider, like LT3042 features. On/off control for example. ![]() Output impedance simulation for LT3042+dienoiser vs LT3082+dienoiser shows that even if LT3042 has a lower output impedance in the first part of the audio spectrum, the LT3082 maintains a more linear impedance throughout the whole audio spectrum. At 20kHz LT3082+dienoiser is still at around 2uOhms. ![]() Going to the ADM7150 we see That LM317+dienoiser has way better PSRR where mains ripple is at. Past 6-7kHz the normal ADM7150 starts showing its performance. ![]() For output impedance between LM317N +dienoiser vs normal ADM7150 the LM317 is way better up to 1MHz. ![]() Adding a dienoiser to ADM7150 seems to require a very large Ref cap vs datasheet. Actually it required it anyway to get a nice response, even without the dienoiser. I don't know if that is a simulation artefact or not, but seems a 1000uF value gives good results. With the dienoiser attached to the ADM7150 the performance increases and I have to move to LT3082+dienoiser for comparison. Again in the mains ripple area the LT3082 is way better but this time the ADM7150 has better performance going past 400Hz and still maintains it upper in frequency. ![]() Keep in mind that this is PSRR. For self noise we see that the LT3082 + dienoiser has better performance than ADM7150 + dienoiser: ![]() Adding the dienoiser to the ADM7150 improves the output impedance but the LT3082+dienoiser still bests it both as absolute value and as linearity. ![]() Of-course these are just simulations. I have yet to try the dienoiser with the LT3082 and until I have it stable these should only be consider theoretical. Might not be possible to add dienoisers to any of LT30x2/ADM7150. I personally favor the LT3082 in sot223 format for low current. Seems an all around good performer for a good price, and sot223 is a very easy to solder package. The part count is also small, and the sot223 version is pin-compatible with the sot223 of lm317. edit: note that I have used TI's model for LM317N. The native model for RH117 has better performance. LT30x2/ADM7150 are native models in LTSpice. For some reason I could only find the fixed voltage versions for the ADM7150 and I used the 5V version. Last edited by Trileru; 4th December 2020 at 09:11 PM. |
#1782 | |
The complete sim may take forever to run, but you only have to look at the beginning, see if there is something like an oscillation build-up. Injecting a moderate amplitude squarewave somewhere in a sim (a current source generally) can also reveal oscillations that would remain buried in the algorithms uncertainties, by forcing them to exceed the threshold allowing the build-up. I repeat: this is no substitute for the final, physical test, but it can help weeding out unpromising alternatives, saving time and experimentation boards, and it goes a step further than just an AC analysis
#1783 |
That is a good idea, thank you! I'll try and do that as well as I'm really curious about the LT3082. It would be great if it worked with the de/dienoiser. Combined with a small cap multiplier in front it seems like an absolute beast! Price and package are desirable as well.
I'll update once I figure out how to simulate it. I prefer to do it before I buy the parts. |
#1784 |
I tried to add the bridge and transformer impedance so I can get more real results and I noticed that there's an issue with output voltage rising very slow (I think a few minutes to reach Vout). Seems to be related to the high value output voltage setting resistor. For 5Vout there's 500k between the dienoiser coupling cap and ground.
The datasheet does mention an alternate scheme for setting the output voltage with lower resistance, and that seems to work faster. For 5V there's still around 7 seconds to reach full output voltage (with dienoiser connected), and for 12V the time rises to around 15 seconds. Here's the two schemes: This is the normal recommended one, and note that for 5Vout you'd need 500K resistance: ![]() Alternate scheme, for 5Vout only 5K is needed: ![]() Theoretically there's an extra resistor vs LM317 and it can easily be integrated into a compatible (new) design. Performance suffers a bit switching to the lower resistance scheme. Still good, but not as before. ![]() ![]() ![]() Last edited by Trileru; 5th December 2020 at 08:37 AM. |
#1785 |
What if you try lt3082 without dienoiser how long will the settling time be?
Can dienoiser work without a C2 capacitor? |
#1786 |
Sorry: what part is Qbcp56? I don't have it on options. What can it be replaced with?
#1787 |
In which post#?
#1788 |
#1789 | |
Without the dienoiser the LT3082 works like a normal regulator. No issues with it that way. I think the 220u coupling cap is too large a value for the output voltage setting resistor. The 220u value is adapted for the typical R2 for LM317? Keeping the same corner frequency (0.1Hz) for 500k I see that 2.2uF should be ok. edit: yes it seems using 1uF-2.2uF for 1.2Meg-500K values for output voltage setting resistor seems to keep the same response, and no issues with output voltage rising time. So the 220uF coupling cap is adequate for the LM317 R2 typical values. So LT3082 can be used (theoretically atm) with only one output voltage setting resistor + dienoiser just that instead of the 220uF coupling cap you need to use somewhere around 2.2uF which is even better size-wise, if I am not mistaken of-course. Last edited by Trileru; 5th December 2020 at 07:50 PM. |
#1790 | |
Here's the models for BCP56/BCP53 pair. Add them to standard.bjt file. These are SOT223 and cheap. They fit good for a cap multiplier.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
PSU upgrade for DAC Magic Plus | E30NA | Digital Line Level | 8 | 1st October 2014 01:00 PM |
Higher-harmonic distortion canceller | jkeny | Solid State | 0 | 30th January 2009 12:39 AM |
LM3886 based Amp -Upgrade advice please. | mikesnowdon | Chip Amps | 3 | 26th October 2008 01:53 PM |
Active crossover - Voodoo magic? | ShinOBIWAN | Multi-Way | 5 | 24th February 2005 03:34 AM |
New To Site? | Need Help? |
