Using MOSFET as ripple filter, help please
I haven't used MOSFETs before. Please look at the accompanying diagram from a Pete Millet PS and tell me if I've identified the drain and the source correctly. Thanks, Steve
Yes that's correct.
Its an N channel mosfet so the current flows from drain to source.
I always remember it by water flows from drain into sewer (source.)
To answer the question, yes, you have identified the terminals correctly.
And no, this isn't the wrong forum necessarily, as this is a fairly common circuit in question, and it is frequently used in power supplies for tube amplifiers, and that's where the schematic posted comes from :)
We discuss a little more than just tubes here you know ;)
Better take all the capacitor and transformer questions too, since they aren't tubes either :D
There's a bunch of cross pollination between these types of things in modern electronics hobby stuff. No sweat.
